Fiat x1/9 boggo standard Magneti Marelli distributor
farrantclose
Hi if you have a Boggo standard fiat x1/9 Magneti Marelli distributor you must every 6 months lubricate it. Undo the clips, take off the rotor arm and you will find a little felt pad. Carefully put a couple of drops of engine oil on this and put the distributor back together again. It is my understanding that many fiat x1/9's were written off for this 5 pence of oil cheap fix thank you. The early '1500' fiat x1/9's are the best i think because no electric Windows and they used the Running parts off Yugo 45's and Zastavas, cheap to Run Clever physics and all done up in a very nice Package thank you
