littlephil
Member
Hello all, im looking at modifying the brown wire to fit a relay in the fuse box so the brown wire running to the ignition switch only triggers the relay and just running the wire from the battery to the relay, then to the fusebox.
the questions I have are, what amperage relay should I use? Was thinking a 70amp. Also what amperage cable should I order to replace the brown wire from the battery? And finally what amperage should I use to replace the ground on the battery?
Thanks all
Thanks all
