I am sorry if this has been answered before, but as I am losing the will I have probably missed it...
I will try to give as much info as possible...
The question is: What is wrong?
Thank you in advance!
- 1989 Grand Finale 1500cc UK Model
- 26000 Miles
- Has been off the road for four years, but DID have the same fault before.
- When you turn the key you hear a click. Then the starter turns very slowly. Sometimes if you retry it will turn quicker other times it just clicks with no turning.
- Removed old alarm and all wiring, making sure any breaks into the loom were repaired.
- Replaced the starter motor with a used, but working one.
- Cleaned the contacts on anything connected to the starter.
- Cleaned the Earth cable contacts around the battery and the chassis.
- Cleaned the Earth cable contacts between the gearbox and the chassis.
- Had replaced the battery twice before so charged up both 12V 40AH batteries, but both are the same! (Both say fully charged on charger)
- The car WILL start on 2nd or 3rd try WHEN jumps leads are attached.
- Car runs and drives perfectly.
- Turn car off and it will NOT start again. Hot, Cold or in between!
- If I put a voltage meter across the battery I get 12-12.4V. When the key is turned to start the voltage drops to 4V.
- On accessory the lights, radio etc work. If the key is turned to start everything goes off….clock, dash lights etc
- Jump leads on and away she goes!
- Going to buy a new 60AH battery tomorrow to try!
