FIAT Auto Specialist Team
Old 21-05-2010   #1
handbrake adjustment
how do i adjust the handbrake? It only clicks 3 times and its not enough. Had an unfortunate incident with it popping out of reverse and sliding very nicely into the front bumper grill of the fiance's auty's 2006 Punto. No damage, its just beyond a joke now. Cheers.
littlephil is offline Reply With Quote Quote
Old 22-05-2010   #2
Wait, I payed for this?
popsprocket's Avatar
popsprocket has donated!
Cat-A-Pult Champion, Speed Cards Champion, Stick Fighter Champion
Australia
Re: handbrake adjustment
My handbrake only clicks three times but works just fine, are your rear brakes functioning properly?
To adjust it get underneath the car and just behind (toward the engine) where the coolant pipes curve away there is a plate with 4 bolts in it. If you undo the bolts and slide the plate away as best you can if you reach up in there just out of sight there is a nut which adjusts the hand brake cable. Unscrew it to loosen the cable, screw to tighten the cable.
popsprocket is offline Reply With Quote Quote
Old 22-05-2010   #3
cheers mate. it just passed the mot last time so i know it needs looking at. Ill have a look at the calipers while i'm there as well. Yours might work ok in oz, but we have lots of hills in lancashire :-) I think that someone might have just clipped the back corner as well that caused it to jump reverse found some scrape marks on the back corner.
Old 24-05-2010   #4
Australia
What pops failed to mention is that adjusting and tightening that nut is a right pain in the arse!!!
Dogdda is offline Reply With Quote Quote
Old 25-05-2010   #5
Australia
Yeah I did, but I figured that does without saying. I got bitten by a spider loosening mine so I could get the cable off the rear calipers.
Old 25-05-2010   #6
Trader Rating: 2
Dare we ask where you got bitten?
78 1400 turbo dallara race X1/9 (for sale - please ask for details)
09 Abarth 500 (for sale - http://www.fiatforum.com/classifieds...=28906&cat=211)
98 1242 8v 6-spd Seicento (for sale - please ask)
jimbro1000 is offline Reply With Quote Quote
Old 25-05-2010   #7
Australia
Just on my hand, I happened to disturb the spider though how the crafty little bugger got in there is beyond me, it's okay though I got revenge.
Old 25-05-2010   #8
Trader Rating: 2
So more of a pain in the hand than a pain in the a**e then
Old 25-05-2010   #9
Australia
A pain the arm to be exact, probably should have seen a doctor but it subsided after an hour or so.
Old 25-05-2010   #10
42 Wallaby Way Sydney
bludvl_x19's Avatar
bludvl_x19 has donated!
Apples Champion
Australia
Quote Originally Posted by popsprocket View Post
Must have only been a small 5 or 6 inch spider then...
Try not to become a man of success but rather try to become a man of value. ~Albert Einstein
bludvl_x19 is offline Reply With Quote Quote
Old 08-09-2012   #11
Ireland
Hi all, I tried the above yesterday and found what I think might be the factory method for adjusting the handbrake. It's WAY easier than taking off the panel with the four bolts.
Just in front of the panel, in the bottom of the radiator hose cover/box there is a small rubber cover about 2 1/2 inches square. That pops out with very little effort and is directly under the adjustment nut for the handbrake. There is enough space to get your 13mm spanner onto it easily and if you use a ratchet spanner the job takes about 5 minutes including jacking and propping the car on an axle stand.
I found it by accident after I had taken off the bolt on panel, undone the gear linkage, dropped one of the handbrake pulleys on the ground, etc, etc.
Dhog4n is offline Reply With Quote Quote
Old 23-09-2012   #12
Thanks Dhog4n, that works and saves a lot of time.
'69 500F 650cc, '87 X1/9 with Abarth camshaft and twin Webers
nathaniel is offline Reply With Quote Quote
(T) Handbrake adjustment tonym911 Punto (Mk2/2b) 6 11-03-2009 21:31
(T) Handbrake Adjustment???? goodgirl156 Cinquecento / Seicento 6 21-09-2008 10:12
(G) Handbrake Adjustment MotorWorldChink Cinquecento / Seicento 16 16-09-2008 13:01
(T) Handbrake Adjustment simondoblo Doblo 6 03-05-2007 18:11
(G) Handbrake Adjustment bodders Marea 1 14-02-2007 16:45
