| X in NZ Hi all, thought I would join up as this is one of the few sites with an X specific forum, and I can spend a lot of time talking about X's.... Have had mine for about 6 months now, but have only driven it for the first time about a month ago for various reasons - ah I have just discovered that you cannot post urls or images as a newbie, but I have a fairly extensive writeup at turbo124 in the members rides section. I will be able to drive the car legally next Wednesday when the registration (Tax) comes off hold - I am gagging for that!
| Re: X in NZ Bump for the 'I am a real live person not a spambot' win
| | #3 | ||
| Re: X in NZ And a couple of vids for you. Idle - 1200 RPM minimum at the moment... a bit lumpy below that ;Bit of a caning...
| | #4 | ||
| Re: X in NZ
| | #5 | ||
| Re: X in NZ
__________________ Current: '07 Peugeot 207 GT. Yes it's French. Used to own: '82 Fiat Superbrava Mk2. Where are you now? In the family at some point: 500, 500 Giardiniera, 850 Sedan x2, 124 Sedan, 132 GLS, Superbrava Mk3, Regata 100S Weekend. | |||
| | #6 | ||
| Re: X in NZ I have some 40 DCNF's to go on - I am getting a pattern made so I can make some manifolds, it should sound much rortier then. Plus I will be able to rev it out a bit more once the engine has a few more miles on it ![]()
| | #7 | ||
| Re: X in NZ All legal and roadworthy drove it around for the morning until it decided to not start for me - battery is a bit tired after sitting with no charge for a year.Goes very well even on the standard carb setup - loves the second choke being open though..... gets right up off it's arse
| | #8 | ||
| Re: X in NZ I hope to get mine sounding and looking near as good as yours....very nice X you have ![]()
| | #9 | ||
| Re: X in NZ If you look at the paint from closer than 10 feet the situation isn't all that flash, however the car is very straight and relatively rust free - but thanks for the comment ![]() I took it out for a good thrash tonight and I saw that the ignition light is on very faintly all the time, doesn't seem to be affected by engine revs, could be the cause of my battery issues maybe. Will have to investigate that one further. Second is that it has a bit of a miss when given the jandal - I suspect the bog standard ignition system is not up to what is being asked of it. I am going to check things over again this weekend and reset the timing etc, but I was wondering if the electronic ignition off a Tipo would be a better bet? I don't really want to get into programmable ECU's and that sort of malarky. even a passive ignition system that takes the load off the points would be a better proposition. If anybody has any ideas on what I could do to improve things, that would be appreciated....
| | #10 | |||
| Back once again w'the... | Re: X in NZ ... Tipo ignition is a bit complex as it depends on a flywheel sensor (Digiplex ECU) and gutted, cam-mounted distributor. Instead I fitted a Regata distributor to my '88 X1/9. I bought the distributor brand new off eBay (from the UK). It arrived with a vacuum advance capsule and in-line cap, but happily the plastic locking/blanking plate (off my X1/9's late-style distributor) fitted. I swapped the balance weights and springs over as well, just in case, and used my right-angle cap. It all looked very 'period style' Considering the Regata was about the same age as the X1/9!An Uno distributor is similar to the Regata design. The finned amplifier module and pickup wires inside can be unreliable, but probably better than the points setup you have at the moment. Remember to use an electronic-type (D-shape) coil as well. Maybe try www.fiatparts.co.nz for the parts. Ignition light on faintly all the time - I eventually solved THAT one by running a 10-gauge amplifier power cable all the way from a large ring terminal (fastened to the alternator) to the big 'brown wires' power connector beside the fusebox. That cured the light problem, charged the battery a lot better, the electric windows went faster, the headlights were brighter, and the wipers were actually fast enough to be useful in the rain ![]() -Alex
| | #11 | ||
| Re: X in NZ Awesome thanks for that - I assume you swapped the advance weights and blanked off the vacuum etc to maintain the same advance for the X engine? Is the Regata distributer a different design to the Uno? ie more reliable innards? getting hold of either type shouldn't be too much drama - I know a man who collects dead fiats and Lancias and keeps about 200 of them in a convenient paddock... I have brackets on my engine for both a flywheel and crank pulley sensor, but the cam I have in it has no distributer drive facility. Thanks..
| | #12 | |||
| Back once again w'the... | Re: X in NZ 200 FIATs and Lancias in a paddock - that would be some find! The Regata distributor was the same as an Uno distributor really, the only difference is that it was brand-new and I got it for 10 pounds complete Yes I wanted to ensure the advance was correct but it was probably the same anyway since it was intended for an 85bhp version of the 1500 engine, just like the X1/9.There will be a bit of a clearance 'issue' in the X1/9 since, for some inexplicable reason, the Uno/Strada/Regata etc. distributors are longer than the X1/9 one (why they didn't make them all short, I don't know). The clearance problem is solved by re-shaping the bolted-on cover behind the driver's seat - you can reverse the curve fairly easily with a mallet - and also you can use a right-angle cap (i.e. one where the leads come out sideways) to help a bit more. Cheers, -Alex
| | #13 | ||
| Re: X in NZ Thanks Alex I went out too see my man yesterday, unfortunately he has got rid of quite a few cars - only about 80 or so now.... ![]() We found an alfa 33 dizzy and the camshaft mounted one from an Uno with the FIRE engine - both more to look at the setups than to use, although I have a coil pack from the Uno as well. The Uno setup has a nice sealed magnetic sensor with a small 4 pole cam magnet thing. At a pinch I reckon I could modify the bits to fit into my X distributor, but only if I cannot get the correct Uno dizzy. The Alfa setup was not really suitable at all. There were plenty of twin cam electronic setups out there but all use the TDC sensor and ring gear speed sensor - bit more of a mission to fit + no real gaurantee that the advance curve would be right + X1/9 has a different number of teeth on the ring gear.... I have a wanted ad on Trademe (the NZ equivalent of eBay, for the benefit of our overseas listeners) for the Uno setup, I will wait and see if that nets me anything suitable.
| | #14 | ||
| Re: X in NZ So being basically thick when it comes to car electrickery, I have a couple of questions about the ignition setup..... 1. Does the X have a ballast resistor in the wiring loom? 2. If it does will this be a problem if I am using a coil pack? 3. Is a coil pack matched to the timing sensor/setup? ie can I use any old random coil pack with whatever pickup/drive module I am using? 4. Can I use a coil pack as a direct replacement for the standard coil without replacing the points setup? 5. Can I use the standard coil with a solid state ignition setup? 6. Will the coil pack be an improvement over the standard coil? 6. How did I get to be a qualified engineer without knowing any of this? I thank you all in advance for the deluge of replies....
| | #15 | |||||
| Re: X in NZ
I am going to use the uno distributer as is - can anyone give me any advice on whether the uno advance will be more or less correct for the Tipo engine? Should I use the vacuum advance or blank it off? Thanks D
