| Right Engine Mount Hi Fellow X1/9 Owners! Does anyone out there know the best way to replace the right engine mount that is by the timing belt. It looks like it's going to be a real battle...in the dark no less...I mean you can't see all of the bolts from the top. Am I suppose to feel my way or go in from the underneath? Thanks in advance!
Last edited by mcheatham : 02-07-2008 at 02:09. Reason: incorrectly spelled word | |||
| Re: Right Engine Mount It shouldn't be too hard, this is how I would do it; - chock the wheels! - drain the cooling system - remove the yellow plastic cambelt cover - slightly raise/support the engine with a jack on the sump at the cambelt end of the motor - undo the bolt from the mount you want to replace - take off the top engine link on the other side of the motor - jack the motor up gently, you should be able to get the mount clear of the body before straining/breaking anything else too much....! - At this point you will need to either remove the pulley from the water pump or remove the whole water pump - remove the cambelt (if you are not confident to do this I would advise not starting )- remove the 3x 17mm bolts - two at the bottom, one tucked in beneath the mount - you may need a long socket for this one. the mount should come off now, you may need to put a drip tray beneath the engine if you didn't drain the coolant - the mount also clamps the water gallery end plate - if that plate is not sealed the quite a lot of coolant will come out... Assembly is the reverse of the above - hope this helps!
Last edited by ladaspeed : 11-07-2008 at 21:03. Reason: Thought of something else | |||
| | #3 | ||
| Re: Right Engine Mount Thanks Ladaspeed! Not sure if that mount is really worth all the effort, though.
| Engine mount | stonecold128 | Panda (Classic) | 2 | 15-12-2006 22:47 |
| The right engine mount | woj | Cinq/Sei > Technical | 7 | 21-10-2006 08:26 |
| engine mount | dmrtim | Panda (Classic) | 8 | 04-03-2006 13:04 |
| engine mount | Bushboy | Cinquecento / Seicento | 1 | 20-04-2005 21:24 |
| Engine mount anyone? | Jaff_Fox | Panda (Classic) | 1 | 15-04-2005 20:37 |
