The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > X1/9
Old 22-06-2008   #1
Hec
Trader Rating: (0)
Where can I get my alternator fixed... In Italy :D
I perhaps rather foolishly have embarked on a tour of europe with my Exxy. I know, i know, was probably too much to expect it to get too far without problems. I had a very thorough service done before leaving the UK and it's been working like a charm until I got to the south of France.
The problem I think is the alternator. The car doesnt turn over but bump starts(!) fine. The battery light had been coming on intermittently for a couple of days before hand. I'm bump starting my way to Italy tomorrow. Surely somewhere in the birthplace of the icsunonove I can get this sorted, can anyone point me in the right direction. Have tried google but i'm not sure of the correct combination of italian to get me going.
Is the alternator interchangeable with one from a 124, Panda or an otherwise standard part? Could it be someting other than my amateur diagnosis of the alternator? Any advice gratefully received
Hec is offline
Old 24-06-2008   #2
Trader Rating: (0)
Netherlands
Re: Where can I get my alternator fixed... In Italy :D
I'm sure ANY Fiat dealership will help you.
If it's the alternator, you can find inexpensive replacements at almost any carpart shop overthere.
Peter Pick-Up is online now
Old 25-06-2008   #3
In the Cone of Silence
bludvl_x19's Avatar
Trader Rating: (0)
bludvl_x19 has donated! Australia
The started problem that I had with my Exxy was almost identical, it wouldn't start, but you could bump start it, and the battery light also engaged. Try shorting out the starter motor terminal and if that works, check the wire leading from the ignition to the solenoid. Mine was loose, meaning the car wouldn't start.
Michael
"I'm so hungry, I could ride a horse. I don't get it, maybe I could ride it to the store."
bludvl_x19 is offline
Old 25-06-2008   #4
Trader Rating: (0)
Look at this thread, it might help you. I did quite a bit of research last year on my 20 year old electrical starting problem.
http://www.fiatforum.com/x1-9/56138-...ng-issues.html
Looking at my last entry on that thread, I did connect a relay to the ignition soleniod lead on the switching side of the realy (post 85/86) and then connected a bigger wire (AWG10) on the power side of the relay (post 30/87) going to the soleniod, I got the power directly from the main starter wire. I housed the relay on driver side firewall in the engine compartment. I might write the schematic of that modification.
Fixing those two problem fixed my starting and other electrical problems.
I don't think push starting (bump start?) your X 1/9 is good for the transmmission.
Bob Lawbla
79 X 1/9 USA (first owner)
74 Spider USA
Bob Lawbla is offline
Old 02-07-2008   #5
Trader Rating: (0)
Did you get your problem sorted? Only just spotted your post but I have details of some garages in Italy (one near Turin, one near*Arezzo) who helped with our X1/9 last year. Cheers, David
aquamarine is offline
vB code is On
Hello from Italy! an_italian_dude Newbie Central 7 26-04-2007 19:37
Anyone from Italy? tazztham Lets Talk FIAT 2 02-05-2006 13:33
A Hello from Italy Nyx Leisure Lounge 3 11-04-2006 14:59
Greetings from Italy electricsheep Stilo 38 27-02-2005 13:50
