| Help checking out 1300 4 gear Fiat X1/9 pls Hello, I'm considering buying an unregistered Fiat X1/9 (so can't test drive), verified '78, 1300 4 gear, 6 hrs drive away. 1) I can get a friend to check rust, particularly behind the front wheels (& behind back wheels?) and the foot well. Anywhere else to check? 2) I have a compression tester which I can send my friend so he can do the Compression Test. Anyone know what readings I should get for compression tests? 135, 135, 135, 135? 3) Claim is that mileage is 15,000 miles (25,000 kms). I want to spring surprise to make sure odometer is connected! Pardon my ignorance. Is odo connected to front wheels, back wheels or drive end of gearbox please? ALSO: Where do the jacks lift it for that test please? 4) How do I check engine mounts? 5) Any other things I should check? 6) If NO rust/scratches, compression is even/high & engine mounts OK, what is it worth please? Bill Oliver
| BLUES+TWOS! PANDA+UNO! | Re: Help checking out 1300 4 gear Fiat X1/9 pls x1/9...........more than the uno, rust, everywhere, and from what my friend has told me, absolutely everywhere, it's of more concern than the engine, the electrics, the condition of the interior...his has been pulled apart and rebuilt gawd knows how many times in the 6 odd years i've known him, and it's always the same....rust the engines are essentially the same as the 1301cc found in the mk1 uno 70sx and turbo, just bigger capacity and no turbo. the turbo swap is quite common apparantly, although he's sticking a honda v6 in his, and the in teh states i think it's a fiero swap thats usual. i wouldn't jack it for fear of snapping it in two....back to the rust thing value? non runner? laid up for a long time? major work? he might have to pay you to take it away...
__________________ ![]() THE MODERATOR FORMERLY KNOWN AS TURBONED 'that my friend, will mash up through the engine block of a Fiat Uno, no problem I'm Andy McNab, I'm Andy McNab, I'm Andy Mc Nab, I'm Andie MacDowell ummmmm... YEAH BUT JAJA BINKS MAKES THE EWOKS LOOK LIKE F*****G SHAFT!!! | ||
| | #3 | ||
| Re: Help checking out 1300 4 gear Fiat X1/9 pls Hi Bill Try this link As for your questions.. 1) Windscreen surround & nose cone 2) 3) Broken speedo cables are common (connected at gearbox) and are very long and not the easiest to fit. Jack points are square section tubes towards the rear wheels. 4) 5) Crunching 3rd gear and have been known to jump out of reverse. 6) hard to say with a none runner, worth what you are prepared to pay for it. Maybe Jimbro could fill in some of the gaps? Great little cars if you can get a good one, if you really want one be prepared to look around. You will be rewarded one the the best drives for not a great deal of money. Happy hunting Dave
| | #4 | ||
| Re: Help checking out 1300 4 gear Fiat X1/9 pls I shall try and fill the gaps then ![]() 2) 135 would be a good reading across the board but keep an eye out for a drop on 2 and 3 as a gasket leak between the two cylinders is not unusual. 4) engine mounts is a bit tricky as the three mounts tend to keep the engine very static when it isn't running. The dogbone mount is easily to examine though, any signs of serious cracking in the rubber means it is time to replace it. The other two are down to observation from the cabin - the side mount rarely fails and unless it snaps wouldn't do much even if it did fail, you just get more noise. The lower mount is the critical one - as it goes the engine sinks a bit - the driveshafts start to rub and you can find the gearchange becomes tricky. A dodgy gearchange is not just down to a weak engine mount though.
__________________ 1400 turbo race X1/9 (250bhp) 1242 8v MPI 6spd Seicento (150+bhp?) ![]() Wolfdirect Racing - for all your tuning requirements (http://www.wolfdirectracing.co.uk) | |||
| | #5 | ||
| Re: Help checking out 1300 4 gear Fiat X1/9 pls More gap to fill ![]() 1) a. The rocker panel (which you can check) and the inner frame (which can't be check without opening up the rocker panel). I had to replace mine. It is the peice which is inside the structural of a convertable car to strentghen it(making up for the roof structure). look at pic. b. Around the windshield frame is an other bad rust spot. c. The shock tower tend to rust terribly d. the rear trunk floor, just above the muffler, then to rust bad (look at pic) 3) I replaced my reverse gear twice and the shaft, since I own the car (since 1980). As a note I used AC/Delco Synchro mesh transmission oil it works good. I also used redline. Yes the 3rd gear grinds, especially with the wrong oil in the transmission. 5) Some interior parts are flimsy, like the glove compartment lid tend to break(really hard to find). the ashtray. The dash cracks on the top. 6) electrical; it has the "big brown wire" engineering problem at the ignition. The small lead to the starter selenoid is too small. some ground wire a way too long (and small) for what they are driven (wiper motor). See various threads. 7) The rear arm bushing I have yet to find any to replace mine. I am thinking of getting some custom made. 8) Rubbing axle noise from bad lower engine mount. I replaced mine. 9) I had to replace my Gulp Valve, which caused a vaccum leak and the motor would not idle. 10) replace pop up light diode in the light raising motor circuit (on the light raising motor itself). But I like the car even since and fun to drive. Cheers! Bob 79 X 1/9 USA 74 Spider USA
| | #6 | ||
| Re: Help checking out 1300 4 gear Fiat X1/9 pls BIG thank you to all so far, particularly the photos. I'll download a manual from that Greek site (can't find it now) to see what some of the terms mean but it looks like checking out will be a full day's job! ![]() btw If two cylinders have gone, that would be exposed by a compression test. Right? The car is 6 hrs away... and maybe that's a safety mechanism in itself! It means I'm really thorough in checking it out, rather than just popping over and falling in love with it! (btw - how come we don't have the smiley with the heartbeat?)
| | #7 | ||
| Re: Help checking out 1300 4 gear Fiat X1/9 pls Hi ,everbody, I have some news about ic_PT4711 PT4711A and PT4711c,hopeting help somebody who need . Description of PT4711 PT4711A and PT4711c you can find what you want in chinaicmart The PT4701 Excalibur™ power module is a 35-watt quad-output DC/DC converter that is designed to meet the power requirements of Texas Instruments’ TNETD7112. The TNETD7112 is a dual-channel line-interface driver/receiver that compliments the AC6 ADSL chipset for use in POTS (plain old telephone service) applications. To conserve power, the TNETD7112 line drivers require two pairs of complimentary power supply voltages. These are ±8 V and ±3.75 V respectively. The PT4701 module operates from a standard (–48 V) telecom central office supply and provides all four supply voltages as two complimentary balanced loads. (This product is not suitable for unbalanced load applications.) The load capacity allows the PT4701 to operate up to 16 line-driver ICs, representing 32 ADSL channels. The PT4701 incorporates many features to simplify system integration. These include a flexible On/Off enable control, input under-voltage lock-out, and over-temperature protection. All outputs are short-circuit protected, and internally sequenced to meet the TNETD7112 power-up and power-down requirements.The module is packaged in a space-saving solderable copper case, requires no heat sink, and can occupy as little as 1.2 in2 of PCB area.
| Tags: buying, compression test, rust, value, x19 |
| 2000 tiptronic pls help! clicking gearstick + flashing gear display when indicating? | DABOSS | Punto > Technical | 1 | 29-10-2006 19:37 |
| fiat 127 1300 gt | antsuno2 | Other Fiats | 7 | 04-10-2006 08:09 |
| fiat 1300 fabricate in 1965 | razvan_gsm2002 | Other Fiats | 1 | 28-06-2005 16:30 |
| clutch problem reverse gear pls help | jonathon | Marea | 7 | 18-04-2005 21:17 |
| Fiat 1300 homemade cabrio | rossi107 | Members Motors | 1 | 01-07-2004 00:26 |
