The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > X1/9
Old 18-04-2008   #1
Trader Rating: (0)
Engine Removal
I searched previous posts on the subject of engine removal from an X19 and all referred to taking the engine out of the bottom. Is it possible to take the engine out of the top? I will not be puttng the engine back in as I am converting my X19 into electric drive, if that makes any difference.
Eagle95 is offline
Old 18-04-2008   #2
jimbro1000's Avatar
Trader Rating: (1)
Re: Engine Removal
The engine bay was not designed to have the engine hauled out of the top but if you were to remove the engine cover from the car and seperate the gearbox from the engine it should come out with relative ease.
You can take the gearbox out at the same time but it just takes more effort to guide everything out cleanly. It all really depends on what hardware you have for lifting.
Relatively speaking it is easier to lift the entire rear of the car via the bumper mounts and leave the engine on the floor than it is to do it the other way around.
1400 turbo race X1/9 (250bhp)
1242 8v MPI 6spd Seicento (135bhp : 150bhp was undriveable)
Abarth 500 SS coming soon(ish)
jimbro1000 is offline
Old 19-04-2008   #3
Trader Rating: (0)
Re: Engine Removal
O.K. Jimbro1000. Thanks for your input. I think I will do as you say and take it out the bottom. It just is a little bit counter to the way I am use to pulling an engine and I guess I have to readjust my thinking.
Eagle95 is offline
Old 01-05-2008   #4
dekx1/9's Avatar
Trader Rating: (0)
Re: Engine Removal
What do you have to take off the engine
dekx1/9 is offline
Old 03-05-2008   #5
Trader Rating: (0)
Re: Engine Removal
I stripped about everything one can take off of the engine and than dropped it out the bottom. Lifted the car up and pulled the engine out from underneath.
Eagle95 is offline
Old 08-05-2008   #6
dekx1/9's Avatar
Trader Rating: (0)
Re: Engine Removal
Ive got loads o problems , how do you split the engine from the gearbox
FIAT X1/9
dekx1/9 is offline
Old 08-05-2008   #7
jimbro1000's Avatar
Trader Rating: (1)
Re: Engine Removal
Remove the starter motor, disconnect the driveshafts from the diff (6 rather tricky allen head bolts on each shaft), unbolt the gearshift linkage and unbolt the clutch slave cylinder from the actuator arm and the casing (support it like you would a brake caliper for the same reasons), disconnect the arm that joins the gearbox to the exhaust then unbolt the gearbox from the engine block. It should basically fall off then unless the clutch has seized onto the flywheel (not unheard of). Make sure that it really is unbolted all around the bellhousing as some of those bolts can be hard to locate.
Old 08-05-2008   #8
dekx1/9's Avatar
Trader Rating: (0)
Re: Engine Removal
thanks ive just about got it out i just didnt know how the driveshafts came out .I think the clutch is nacked
FIAT X1/9
dekx1/9 is offline
vB code is On
Tempra Deisel engine removal nverona Tempra 3 11-11-2007 12:40
Engine removal Brooky Cinquecento / Seicento 15 23-05-2007 21:55
Engine Mount Removal-1.2 Punto 8v neil-sri Punto 0 05-04-2007 22:08
engine removal jtd nickmcd Multipla 0 03-08-2006 09:01
cinq engine removal 99sei Cinq/Sei > Technical 22 11-02-2006 14:24
