| hi all... i was thinking...how could i get a gearstick in a X1/9 to look like the one below... many thanks Brian
| Re: |Need Some More Help lol| Its been done, you first would have to build a center console to house it, and brinh it to the correct height. then extend the gearstick etc etc p1x200 have done one in their lastet project.
__________________ Faran Eliminator/ Fiat x1/9 - 2 litre Lancia twin cam Race car Fiat x1/9 vs track day car, 1500cc twin webbers etc = 133 bhp Fiat x1/9 Lido 1300cc Fiat x1/9 1500cc Standard | |||
| | #3 | ||
| Re: |Need Some More Help lol| i just had a look on google for p1x200 and couldn't find anything.... i am bit of a noob to X1/9's could u explain what u mean by that? thanks brian
| | #4 | ||
| | #5 | ||
| Re: |Need Some More Help lol| A word of warning on this subject The X1/9 gearshift is (as I'm sure you've noticed already) a bit sloppy. Whilst in gear you can move the gearstick side-to-side across its entire range of movement. This isn't intentional of course, it is just the way it ends up. If you go for a nice external gate like this you *have* to be prepared for some serious noise and vibration from the stick vibrating against the gate unless you take measures to dampen the vibration. I would suggest shortening the gearstick and using the lightest gearknob you can find (the stock 5-speed one is pretty good actually). The gate itself would be a matter of experimentation as the exact shift points in the horizontal plane are not precise and depend on how the gearbox is feeling and how tough your engine mounts are, not forgetting the lollipop joint in the linkage. If you "feel" how the linkage shifts from say 2nd to 3rd you will find it doesn't just shift up, then across, then up again, instead it is basically a diagonal movement direct from 2nd to 3rd with a short vertical section at the start and finish of the movement. This isn't a matter of being sloppy, it is how the mechanism works and very deliberate. It can all be done of course but you couldn't just grab an old gate from a 70's Ferrari and expect it to work...
__________________ 1400 turbo race X1/9 (250bhp) 1242 8v MPI 6spd Seicento (135bhp : 150bhp was undriveable) Abarth 500 SS coming soon(ish) | |||
| | #6 | ||
| Re: |Need Some More Help lol| hi jimbro i wasn't expecting it to be easy TBH....i just wanting to know if it could be done...and how it would be done...lol... so you are saying.... 1. shortening the gearstick and using the lightest gearknob 2. find out how big the gates have to be...(could i just measure it from when it is in netural to when in gear...then draw the gate to the measurements on carboard and cut it out and see if it touchs....then try it with stainless steel and hope for no diffence). ![]() thanks brian
| | #7 | ||
| Re: |Need Some More Help lol| Shortening the gearstick is just an effort to remove some of the large vibration you get, effectively you are raising the frequency of the vibration which could prove to be worse if I am wrong so don't go cutting the gearstick yet. This is theoretical.... maybe I should have said that earlier. For the gate I would suggest working with somehting like high density styrene sheet, it is flexible, fairly easy to cut and you can stick a few layers together to make something more solid. The main point about the gate is that it won't be just a single horizontal sweep with vertical appertures along it (mimicing the pattern shown on the gearknob). Instead you will have to shape the gate to look more like a saw blade. (I'll try and put a mock-up illustration together and post it here later). You *could* go with the traditional "H" gate but you may find you have to double clutch in order to change gear cleanly if you do.
| | #8 | ||
| Re: |Need Some More Help lol| This is the sort of shape I think you'll end up with: ![]()
| | #9 | ||
| Re: |Need Some More Help lol| thanks jimbro i will make a template of it now and try it out thanks brian
| | #10 | ||
| Re: |Need Some More Help lol| hi i have got me dad to get me some aluimuim from work to create the housing for it...i should start making it tomoz...i will put pictures of it when it is nearly done.... brae
| Lol | GhostWKD | Leisure Lounge | 12 | 09-08-2007 10:02 |
| Hi n Help lol | scots1_2000 | Leisure Lounge | 15 | 31-05-2007 17:54 |
| parents new car/my free run about lol (i told em to get it lol) | Dunc Uno Turbo | Members Motors (Non-FIAT) | 25 | 07-06-2006 17:37 |
| Lol, what would this really do? | Randomman | Leisure Lounge | 13 | 24-10-2005 22:02 |
