The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > X1/9
Old 08-03-2008   #1
Trader Rating: (0)
noob
just brought home my new x1/9. i'll take some pics directly and put on my photobucket. few questions....one) it overheats very easily? any takers?
2) if i get you the vin, could someone tell me what options and such the car came with?
thanks a lot guys
blysccr@yahoo.com is offline
Old 09-03-2008   #2
jimbro1000's Avatar
Trader Rating: (1)
Re: noob
Can't help with the second point but for the first one it is likely to be down to either a blocked radiator, a jammed thermostat, engine running too lean or a blown headgasket.
Run a compression test first and see what happens and post the results here.
Jammed thermostats are not unheard of especially if the car has been stood for any length of time. Similar circumstances can result in the radiator blocking up, you can try flushing it but the odds are that if it is blocked the only real choice is likely to be a new radiator. Even if you do unblock the radiator you may find it starts to leak like a sieve...
1400 turbo race X1/9 (250bhp)
1242 8v MPI 6spd Seicento (135bhp : 150bhp was undriveable)
Abarth 500 SS coming soon(ish)
jimbro1000 is offline
Old 10-03-2008   #3
Trader Rating: (0)
Re: noob
hi there
if you need a rad i have two recored unused units to clear.message me if you are interested.cheers - mike
mikey k is offline
Old 15-03-2008   #4
Trader Rating: (0)
Re: noob
ok thanks, i'll have to take a look at the t stat and rad. i was under the engine cover i guess you call it and the side of the engine that faces the passenger compartment is all cruddy.....so i'm thinking head gasket. i'll let you know if i end up needing one. thanks
Old 16-03-2008   #5
jimbro1000's Avatar
Trader Rating: (1)
Re: noob
Thats more likely to be the thin paper gasket between the head and the cam carrier, never seen one yet that doesn't leak!
(G) Noob Looking to buy a seicento sporting mali Cinquecento / Seicento 4 28-02-2008 00:55
(G) Noob needs guidance on how to remove and fit new coil pack on 1.6 dynamic!! amblin Stilo 2 17-11-2007 12:47
Noob question on winrar maps Infiniium Satellite Navigation 0 25-10-2007 11:33
(T) Obligatory Noob tuning questions woodins Cinquecento / Seicento 8 29-07-2006 00:06
