I need help with the hydraulics PLEASE! I've been hitting my head
on this stone wall of a problem for two weeks. My '78 X1/9 has been
sitting for 5 years and the last thing I did to it b4 that was replace
the master and slave clutch cylinders. I never could get pressure then
and I still can't. I've pulled the new master out and inserted an old one after using a brake hone on it and replacing the seals. I've re-routed the supply line, thinking maybe it was pinched under the dash. I've replaced the flexible line to the slave cylinder. I've tried pressure bleeding at the fluid supply end and a power suction bleeder at the slave end. At this point I'm getting occasional pressure that causes fluid to spray out of the supply cap if it's closed. I think this is a hint of where the problem is. HELP!
TIA
TIA
