The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > X1/9
Old 05-04-2007   #1
Trader Rating: (0)
South Africa
X1/9 1600 16v conversion
Just thought i'd hear what tiy guys think.
I just bought a 1.6 16v motor from a palio. Busy putting it in my x1/9. The motor is in, i'm busy with engine mountings for the front and rear of the engin. Its quite a tight fit, but mostly dew to the fact that i tilted the engine as far forward as possible.
Will post some pics over the weekend.
X19.za is offline
Old 05-04-2007   #2
exxy51's Avatar
Trader Rating: (0)
Re: X1/9 1600 16v conversion
sounds good lookin forward to the pics. good engine to transplant because it is the same engine as the original x19 just updated.
Faran Eliminator/ Fiat x1/9 - 2 litre Lancia twin cam Race car
Fiat x1/9 vs track day car, 1500cc twin webbers etc = 133 bhp
Fiat x1/9 Lido 1300cc
Fiat x1/9 1500cc Standard
exxy51 is offline
Old 10-04-2007   #3
Trader Rating: (0)
South Africa
Here are some pics of the lay out and the temp mountings.
X19.za is offline
Old 14-04-2007   #4
Eoin611's Avatar
Trader Rating: (0)
Ireland
Sounds like a fun combination. Have a race x1/9 with 2.2vtec in the back, have a clean shell to put on the road but would prefer to keep it Fiat powered. Keep us posted on how it works out.
Eoin611 is offline
Old 17-04-2007   #5
Trader Rating: (0)
South Africa
I had a 1,6 16v toyota motor, with turbo conversion, but i couldnt get myself putting it in. 2.2vtec must have felt really good!!!
I am looking for a new management at the moment, the one i used on my 1300 motor with F/I does not run wasted spark.
I'm busy selling off some of my 128 motors and the old management to buy the new management.
X19.za is offline
Old 18-04-2007   #6
hydrocat's Avatar
Trader Rating: (0)
South Africa
What management system did you use on the 128's and which head did you use.....Uno turbo?
Pse. post spec on the 128.....I might be interested.
hydrocat is offline
Old 18-04-2007   #7
Trader Rating: (0)
South Africa
i used mr turbo mfi. Just used the uno turbo intake manifold, fuelrail and injectors. I changed the dizzy to electric one as my FMS could run fuel and spark. Never had it dynod but ran a 16.93sec 1/4 mile with it in the uno.
The motor has been bored to 87mm, and i've put in a uno crank to give it 1580cc. I used the std 128 head.
I have another 128 block, 87mm low cr pistons, o ringed block, Uno turbo crank, new bearing. Not been built.
X19.za is offline
Old 18-04-2007   #8
M@nticore's Avatar
Trader Rating: (0)
South Africa
how much u want 4 it, but i'm actually looking 4 NA, will my current 1400 head fit on one of those engines?, and does it fit on standart mntings
1400 uno pacer sx, 15" mags, free flow, induction kit, ut front brakes,50 HP NOS nitrous kit. still sorting out rear disc brakes from old RIP uno.
M@nticore is offline
Old 18-04-2007   #9
Trader Rating: (0)
South Africa
Yes the uno head will fit BUT you need to drill the holes for the head bolts bigger. The one with the low cr is build to have 8,5:1 cr with an uno turbo head, with a pacer head it should make the cr a bit higher. Mountings are the same, you use the uno mounting on the side.
I am looking for R2500 for the complete motor and R1500 for just the block.
X19.za is offline
Old 06-06-2007   #10
M@nticore's Avatar
Trader Rating: (0)
South Africa
the engine that u want to sell, does it have forged pistons or standart bits?, and whats the milage on the engine?
Old 12-06-2007   #11
Trader Rating: (0)
South Africa
The block is sold, i only have the complete 1600 motor. Its standard piston. If it has done 5000km it would be alot.
X19.za is offline
Old 20-11-2007   #12
Trader Rating: (0)
Sorry for raising a RIP thread. I am a new owner and am wondering if the X1/9 is big enough to take a 16v (or even a 20v) toyota 4age engine. and what gearbox would it use ? (the original or the 4age gearbox?) thanks.
venice is offline
Old 19-08-2008   #13
FiatGroup's Avatar
Trader Rating: (0)
This is completely wrong installation
You can install with orginal carrier
ID:	48836  Click image for larger version
FiatGroup is offline
(T) 1600 16v to 1400 uno gearbox fit. M@nticore Uno 5 26-09-2006 15:52
X1/9 with 16v head? Aceuno X1/9 2 04-01-2006 15:23
(G) Fiat Bravo 1.8 16V Conversion Ivo Bravo / Brava 10 29-10-2005 16:33
126 1.8 16v reno valver conversion Fun Size Other Fiats 9 26-12-2004 00:48
My X1/9 twin cam conversion fiatfactory X1/9 2 19-08-2004 13:59
