The gearstick is very stiff but it goes into all them, when the car is in gear and moving there is a grinding sound but its not there when the clutch is pushed in, apparently the clutch cable has been changed recently as it snapped on the previous owner less than 500 miles ago basically. the clutch pedal only has to be bought off the floor about an inch maybe less for the car to be pull off etc.
I'm hopeing its not the gearbox but can anyone see the problem here from what i have described? the clutch slipped on a few occasions about 1k ago but only on full boost at about 3k.
could it be someone hasnt fitted the cable correctly?
thanks
Mark.
P.S its a top change MK1 turbo
thanks
Mark.
