The FIAT Forum
Old 15-09-2006   #1
Mighty v6 power
Rob-mint-mk1-uno's Avatar
Trader Rating: (0)
Rob-mint-mk1-uno has donated! United Kingdom
Digital Dash Wanted
hi there
I have been after a digital dash board for a while now does and body have one for sale or any good pic's of one.
Also how do i get a pic of my car underneath my name like you lot have ive added a pic to my profile but it wont appear under my name to the left of this message.. any body help me
Rob-mint-mk1-uno is offline
Old 15-09-2006   #2
RIP L181 VBB
AppleSei's Avatar
Trader Rating: (4)
AppleSei has donated! United Kingdom
Re: Digital Dash Wanted
Any wanted ads for hopeful purcahse need to be put in classifieds
Check ebay as well and the gallery for any unos to see if they have a pic of one
To add a avatar/pic under your username go to 'user CP' then 'edit avatar'
2001 Modded Sei Sporting - GONE!!
1998 Ford Mondeo 1.8LX - P/X'ed
2002 02 Ford Focus 1.6 Zetec w/ Climate Pack!
AppleSei is offline
Old 15-09-2006   #3
Mighty v6 power
Trader Rating: (0)
Sorted me pic, thanks bud and soz for putting that in here...
Old 15-09-2006   #4
RIP L181 VBB
AppleSei's Avatar
Trader Rating: (4)
No need to apologise, you are fairly new, next time though, the hounds may be released
Youre not the first and you wont be the last
AppleSei is offline
Old 15-09-2006   #5
Classic Uno Obsessive
1986Uno45S's Avatar
Trader Rating: (0)
Drives:
1986Uno45S has donated! United Kingdom
Rob, I've seen digital dashboards turn up on Ebay, but they aren't common and can often command high prices. They were available as a mk1 option only, so not many were fitted with them as most came with analogue instruments.
As Apple mentioned, Ebay and the classifieds on here are your best bet. Keep looking and you'll find one eventually
Originally Posted by Trinity View Post
we got a lot 126 here in Egypt .. a funny car and fun to drive though sometimes i feel like I am sitting on a chair in the middle of the street
http://onastick.net/drew/sinistar/
1986Uno45S is offline
Old 15-09-2006   #6
Mighty v6 power
Trader Rating: (0)
Yeah i check e bay just about every hour but seen nothing, i have a pic of the dash looks pretty trick..
Do you know if it uses the same loom and how much shud i look to pay for one..
Old 15-09-2006   #7
1986Uno45S's Avatar
Trader Rating: (0)
Drives:
They turn up every now and then. They also seem to be quite popular in Germany, and if you're lucky the dash might have a switch to go from kph to mph like a lot of modern cars do. If this is the case you might be able to find one on German Ebay.
I've seen them go for as much as 40 pounds!
I think they use the same wiring loom as the standard dash, but I do know that the boost gauge is electronic whereas the analogue dash boost is run off a vacuum pipe. Apparently there is a pin on the ECU which sends the correct signal but you'll need one of the turbo boys to confirm this.
Good luck with the project!
Old 15-09-2006   #8
Mighty v6 power
Trader Rating: (0)
Yeah here's a pic i think you can just make out that switch av a look
Old 16-09-2006   #9
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
Hmmm... I don't think there is a switch; the Tipo DGT has the switch, but the Uno Turbo display is clearly labelled 'km/h'. Good for us of course (in metric New Zealand), and actually over here it doesn't matter if your speedo is in miles per hour or kilometres per hour. It could probably be in metres per second, Mach number, percentage of chance to die in a crash, or light years per millenia... all the WOF inspection states is that the vehicle 'must have a working speedometer'.
If it's anything like the Tipo DGT unit (which it probably is), you'd find the Uno Turbo digital instrumentation to be an absolute pain in sunny conditions - because the segments are backlit and non-reflective, they are completely drowned out by low-angle sunlight. In fact, they've been mostly obliterated by the flash in that pic. I got a speeding ticket last year because of sunlight (in a Tipo), I was overtaking and honestly had no idea what speed I reached - apparently 115km/h, surprising when the car was running on three cylinders.
Update: just checked in my Mk1 Uno handbook - circular button in the lower-left corner is for resetting the trip meter. There is no mention made of changing the units (and if you could, you wouldn't be able to change the odometer or trip meter units anyway). You may find a setting somewhere in the circuitry, so it would still be worth a check if not too expensive.
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 16-09-2006   #10
Mighty v6 power
Trader Rating: (0)
Ah i thought that switch was to change it but now you say it, it is clearly labled km/h and no mph present ???
I had an old astra gte 16v a couple months ago and when the sun was behind you you coundn't see it at all it just looked black and dull
may be i should just get some white dial's and slap in my dash they look pretty sweet. Is this a easy job alex...
Old 16-09-2006   #11
the mk1 kid's Avatar
Trader Rating: (0)
They do switch mine did and it was great fun seeing how many times in one journey you could see over 200 kph! (i spend a lot of time on my private roads)
So you're looking for a cheaper one on another site! lol
Tom
Mk1 uno t: Fast road Colombo Bariani cam, gas flowed polished and ported head, new pistons and bearings, big turbo, custom front mount IC and when complete it will run punto gt1 management with a SEB POTR 4.1 chip. Waiting with the management is now a techniclutch jobby and a 3.5kg flywheel!
the mk1 kid is offline
Old 16-09-2006   #12
Mighty v6 power
Trader Rating: (0)
Ere mk1 kid, your uno sounds alrite? wheres your pic's @ i wanna see it....
Old 16-09-2006   #13
Mighty v6 power
Trader Rating: (0)
Ere
Heres another pic and i think you can just make out the kph and mph above it, maybe you can change them between the 2.
Any body else know???
I wont let me put it on itsto big but it does look like it can be swapped round
Old 16-09-2006   #14
Trader Rating: (0)
I've posted the odd pic before.. Its waiting to be sprayed (one day this year maybe..) Until then i'll keep it under wraps a little
Tom
Old 16-09-2006   #15
Mighty v6 power
Trader Rating: (0)
-Alex
Mate look in the other thread MINT MARK 1UNO NEED HELP theres a guy on there with a digital dash it does miles amd kph... take a look
