The FIAT Forum
Old 08-09-2006   #1
Trader Rating: (0)
Unoturbo'd has donated! United Kingdom
smoking uno turbo after rebuild
hi i'm trying to find the cause of my uno turbo mk1 smoking. the engine had 81,000 and has been refreshed with new piston rings and new polished and ported head. not sure on the condition of the turbo though, i seem to let out loads of blue smoke on deceleration after its been drove hard. last time i checked the plugs they were nice and brown, will check again tomorrow. This is my second engine as a piston ring went in my last 1 and that smoked all the time. luckily found this mk1 turbo engine which had so much less wear in the bores i decided to get new rings anyhow. can any1 help thanks
Unoturbo'd is offline
Old 08-09-2006   #2
Banned
Trader Rating: (2)
Bushboy has donated!
Re: smoking uno turbo after rebuild
could be the seals on the turbo letting oil in where it shoudlnt get and its burning it.. hence the smoke. check the turbo over.
Bushboy is offline
Old 08-09-2006   #3
Trader Rating: (0)
i was thinking the same, if i remember back there was very slight play in the turbo, but wasn't sure if it could cause all the smoke
Old 09-09-2006   #4
the mk1 kid's Avatar
Trader Rating: (0)
IMO its your turbo that causing the smoke. 80k isn't much for an IHI they are tough little cookies but if in the past its had a bad supply of oil, quantity or quality then that would explain it.
Remove the plugs, if they are oily then it could be something to do with the rebuild and wont be the turbo
Remove the turbo elbow and see if there is an oily coating in there, i expect there is and the turbo is to blame.
Tom
Mk1 uno t: Fast road Colombo Bariani cam, gas flowed polished and ported head, new pistons and bearings, big turbo, custom front mount IC and when complete it will run punto gt1 management with a SEB POTR 4.1 chip. Waiting with the management is now a techniclutch jobby and a 3.5kg flywheel!
the mk1 kid is offline
Old 09-09-2006   #5
Trader Rating: (0)
i looked at the spark plugs again today and they are nice and brown no sign of oil, so it looks like the turbo is at fault and there is quite a lot of oil in the boost pipes. bit alkward to take that elbow pipe of but will do soon too verify for sure. thanks for your help
Old 09-09-2006   #6
Trader Rating: (0)
No worries.
It is a right pain getting those nuts off just take you time and get the perfect socket on them. If you have access to some gas get some heat on them and metaphorically speaking you could undo them with your fingers!
As you would have the inlet off no doubt already why not remove the turbo and the elbow from the downpipe. the turbo has the same amount of bolts and when off if found to be no good its one less thing to do.
Tom
(G) smoking uno turbo dspadge Uno 0 08-08-2006 21:34
Ten of the Best? alainax Leisure Lounge 16 04-08-2006 01:03
Newbie - Uno Turbo Owner charged Newbie Central 6 15-04-2006 00:02
