Thread Tools
Old 14-08-2006   #1
Norway
How to build a Mk1 Uno Turbo 200bph engine !
Hello..
Finally started my project, which I would like to call "FerrUNO" Ferr of Ferrari as the car is going to be painted in Ferrari Red. More about the car will come in another post. Sorry for my frequently bad english
The car/enigine is an 1986 Fiat Turbo I.E ( Mk1 ) 1.3l
The car is not going to be registrated on the road for ordinary road use
My plan is to get around 200bhp of the engine, but iam not very experienced in engine tuning. What kind of modifications should I do ?
This is some parts that I've already purchased :
- Brand new uppgrade Mitsubishi Evo8 IC ( Good for 4-500hk) ( BIG! )
- Brand new Clutch from techniclutch in england. Should hold 220bhp or so.
- ('95) Saab 9000T Injectors
Planning to purchase:
- Building new custum exhoust system 2.5" the whole way.
- Chip the engine management ( If its possible ?!? )
- Upgrade the turbo with a larger exhoust-house ?!?! ( is it necesary ? )
Haven't buyed so much parts yet, but i have the whole winter on me to build the car !
Any suggestions on parts that I should buy, and what I should do to make a "200bhp" engine ?
'93 Audi S2 ABY - MTM303RS
'86 Fiat Uno Turbo I.E "FerrUNO"
'84 Fiat Uno 1.0 ( 45S ) Spare parts car !
[x]90 Audi 100 Avant Quattro Type44
[x] '91 Audi Coupe Quattro 20v
v|ncenT^ is offline Reply With Quote Quote
Old 14-08-2006   #2
Shut Up, Fool!
thepottleflump's Avatar
thepottleflump has donated!
Re: How to build a Mk1 Uno Turbo 200bph engine !
Good good another Uno project, should be interesting to see the progress. Good luck.
Quote Originally Posted by v|ncenT^
Out of interest why have you bought these for a Fiat Uno project?
1999 Alfa Romeo GTV V6
thepottleflump is offline Reply With Quote Quote
Old 14-08-2006   #3
Norway
Quote Originally Posted by thepottleflump
Buyed the IC because the orginal was so small, and because it will look very nice on the car ! Got it cheap to
The clutch because the orginal on the engine is done, and i wanted something stronger that will last.
Saab injectors because they will give more fuel than the stock ones, with a another fuel regulator.
Anybody know if the bottom of the engine will hold 200bhp, before I have to change rods and so ?
Old 15-08-2006   #4
Trader Rating: 1
mk1 engine can hold 200bhp no probs
oldskoolmk1unoturbo is offline Reply With Quote Quote
Old 15-08-2006   #5
Norway
Quote Originally Posted by oldskoolmk1unoturbo
Nice, that is saving me from spending alot of money
But any suggestions on witch modifications i should do to the engine ?
Old 15-08-2006   #6
Trader Rating: 1
my engine has the following
lightened and balanced bottom end,
lightened flywheel
fast road piper cam
ported head with matched manifolds
oversize pistons
Hybrid Turbo
Fse Boost valve
K&N filter
Scorpion Exhaust
sierra Cosworth intercooler
samco turbo and coolant hose's
p.s the standard management cannot be chipped. i'm eventually going to get a dta or omex management
Old 15-08-2006   #7
You could use a 5th and 6th injector set up for circa 190bhp. The additional injector route isnt the best but its cheap costing around 200 for injectors and controller.
I am slowly getting around to converting my uno to run punto gt managment but my uno lives miles away at my parents and all i have achieved so far is collecting all the bits. This isnt an easy route and as yet i havent heard of anyone doing it but as the gt ecu can be chipped (i have that too) 200bhp shouldn't be a problem.
Tom
Wide arched 89' mk1 uno turbo in white with 8" wide black compo's
the mk1 kid is offline Reply With Quote Quote
Old 15-08-2006   #8
Sweden
Hello..
First of all, nice project!
You defenetly need a bigger turbo.. The stock turbo (IHI VL2/3) can not produce more than 130 hp..
Fiat coupe 20v turbo
Fiat uno 355 hp
Fiat x1/9 (with 1.3 l turbo)
Fiat x1/9 (soon with 2.0l 16v turbo)
uno_jens. is offline Reply With Quote Quote
Old 16-08-2006   #9
Trader Rating: 2
Dunc Uno Turbo has donated!
very nice project you have going there. i remember those days of a bare shell!!
Dunc
Fiat Uno 2.0 16v Turbo - Being Built!
Mercedes A200 Turbo - Daily!
Vauxhall Combo - Daily!
Renault Clio Williams No.106 - Sold!
Dunc Uno Turbo is offline Reply With Quote Quote
Old 16-08-2006   #10
Norway
What kind of turbo should i look after, and can i use the orginal manifoild on it ?
Old 16-08-2006   #11
Sweden
You can use the standard manifold, if you build an adapter for the specified turbo..
Many people use Td04 12-16 with good results..
Fiat uno 355 hp
Old 16-08-2006   #12
Trader Rating: 2
Biz has donated!
Id say start at every aspect of the engine
If you want a usable 200, then check this mk1 (old spec tho!......but damm fast!):
JAJA'S UNO TURBO MK
ENGINE/SUSPENSION/BRAKE MODS !!!!!!
k&n air filter
scorpion 4" exhaust system
Fiat Uno 70 N/A cam
gas flowed and ported head
3 angled valve seats
sach boge clutch
5th & 6th injector
lightened and balanced flywheel
MK 2 uno turbo manifold
Turbo Technics garrett hybrid
cosworth intercooler
relocated mocal oil cooler
Grp N head gasket
boost currently set at 1bar without the 6th injector set up ( can handle 2 bar with 6th injector )
splitfire leads
bosch 4 point plugs
turbo excess 110db @10psi dump valve
tarox 6 groove discs
EBC fast road pads
AVO ridehieght / damping adjustable coilovers
OMP front strut brace
OMP rear strut brace
BODY MODS AND STUFF !!!!!!!
15" compomotive mo's in white
de-badged / de-locked
MK2 back bumper
smoothed tailgate
smoothed bumpers and skirts
Turbo Collective meshed front grille
clear indicators
clear rear light clusters
resprayed in ford pacifica blue
punto rear wiper arm
ICE / SECURITY!!!!!!!!!!!!!
toad alarm and immobiliser
alpine head unit
PERFORMANCE!!!!!!!!!
195.8bhp @6541rpm running 1.4 bar boost !!!! 176.3lb torque @5216rpm
One day I will be champion.
Biz is offline Reply With Quote Quote
Old 21-08-2006   #13
Back in a 500!
alexGS's Avatar
Trader Rating: 1
alexGS has donated!
New Zealand
v|ncenT^, (a tricky name to spell right!)
Nice project! And welcome to the forum
Since it's not for road use, (and presumably therefore only needs to have 200bhp occasionally) have you thought about using nitrous?
Although I have no experience of it myself, I understand that nitrous (nitrous oxide, 'Noz') is particularly good for turbocharged engines since it cools the intake air charge, offsetting some of the temperature from the pressure increase.
-Alex
(or should that be ->A13x )
'14 VW Golf 1.4TSi, '08 500 Lounge 1.4 Dualogic, '03 Stilo Abarth Selespeed, '08 G Spyder, '71 850 Coupe in bits...
alexGS is offline Reply With Quote Quote
Old 21-08-2006   #14
Norway
Quote Originally Posted by alexGS
-Alex
Thank you... Just so you know, my real name is Anders
NOS is not an option, It will be the cheapest of course, but I will build the motor in the old way, with larger turbo and so on.. There is not many places in Norway you can fill up an empty NOS bottle
Old 13-10-2006   #15
Norway
Okey, heres another set up I have thought about :
Found a Fiat Uno MK2/Punto Turbo 1.4l Ex-manifoild with engineered channels for better flow ( With a garret turbo flens as standard )
And a Garett GT25 or GT28 ?
How about that ?
Or should i go for a orginal manifoild, and get welded a new flens for a Mitsubishi TD04 16T Turbo ?
And the key is also now, what will be best on my 200bhp engine ?
Thread Tools
(G) how many uno's on the road???? beau Uno 160 13-02-2012 20:08
(G) How many Puntos are there on the Forum? - The Thread FiatStiloJTD Punto (Mk2/2b) 543 06-06-2008 17:15
