The FIAT Forum
Old 11-08-2006   #1
Trader Rating: (0)
waiste gate / dump valve
on my car i have a waiste gate which i prefer the sound of.
what is the difference between the 2 is it that the w/g throws air out and sucks it in at the same time, where the d/v just gets rid of it all.
uno170bhp is offline
Old 12-08-2006   #2
Trader Rating: (0)
New Zealand
Re: waiste gate / dump valve
Wastegate vents exhaust manifold pressure to regulate boost pressure.
Dump valve vents excess boost pressure in the boost pipes created when the throttle is snapped shut.
SteveNZ is offline
Old 12-08-2006   #3
Trader Rating: (0)
and in english
so is there any difference in performance
Old 12-08-2006   #4
Biz
The Big-Indecisive-Zebra!
Biz's Avatar
Trader Rating: (2)
Biz has donated! United Kingdom
The wastegate is what makes the turbo a usable component
A dump valve aids the turbo so it will keep spinning between gear changes (Stop compressor stall or Air Flow Meter flutter)
Both the above are bad for the two mentioned components but compressor stall and waste gate chatter are the ********! lol
type: AUDI in www.streetfire.net search and youll hear why!
Torque wins races and puts people in their places!!!
From B a r r y boys: "A mate of mine had an Uno turbo donkeys years ago. It was a bloody rapid little thing, but about as refined as sitting in a washing machine full of nails on full spin. Great fun though."
Biz is offline
Old 12-08-2006   #5
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
To expand on what Steve said...
The standard Uno Turbo has both a wastegate and a dump valve. You don't normally hear either of these because they are 'internal' and 'recirculating' respectively.
The wastegate opens to give the exhaust gas an easy path to the muffler, not going through the turbocharger. This prevents the turbocharger from working too hard, so the wastegate limits the maximum boost pressure (normal limit: 0.6bar). This is to ensure reliability of the engine by restricting the maximum temperatures and loads.
If you have a bleed valve fitted, it changes the point at which the waste gate opens. It's called a bleed valve because it bleeds off some of the pressure in the pipe to the wastegate opener (correctly called 'actuator'), so that the wastegate doesn't open until the boost pressure gets higher than normal.
I'm guessing that you have an 'external' wastegate, which I'm also guessing will release the exhaust gas directly to the surroundings? Apart from the noise I can't see any other difference in performance apart from probably having the actuator calibrated to a higher pressure than standard.
If there is boost pressure going into the engine, and then the accelerator is released sharply, the throttle plate closes and the boost pressure momentarily has nowhere to go - excess boost could surge back into the turbocharger's outlet causing 'compressor surge'. The dump valve opens in these conditions to let the excess boost go around into the inlet of the turbocharger (recirculating type), or an aftermarket external dump valve lets the excess boost out into the surroundings as a Tsshhhhhhh.
(This loss of boost then means that when the throttle re-opens, the turbocharger cannot build up boost pressure again until more air has been drawn in, which in so doing comes through the fuel injection system's airflow meter... causing the fuel injection to inject more fuel to match the extra air... and for this reason I personally don't see the point of an external dump valve, even though they are cool to have.)
Incidentally Biz is absolutely right in pointing out the very real purpose of both these components, which is why the Uno Turbo has both (wastegate+dump valve) as standard.
Hope this helps, please say if still confused
I'm thinking you must have a larger turbo as well to get 170bhp, so maybe you'd like to share what your setup includes?
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 13-08-2006   #6
Trader Rating: (0)
all i know is that it has a hybrid , fuel modification , upgrade actuactor and the other little bits eg k+n. i have dyno print out of 170bhp / 180 torque .
i can hear the w/g but not the d/v . wehre the d/v goes it is blocked of
Old 13-08-2006   #7
Trader Rating: (0)
New Zealand
How do you know you can here the WG? Unless it has no exhaust (or a "screamer" pipe) you cant.
What exactly do you want to know?
SteveNZ is offline
Old 13-08-2006   #8
Biz
Biz's Avatar
Trader Rating: (2)
Standard Uno Turbos have a BOSCH bypass valve (No noise when coming off the throttle)
Uno170 mate is the noise you hear of a flutter? (like a pigeon in a way)
on my old MK2 i used a sized ****ty dump-valve and that caused the un-used air when i came off the throttle to go back past the turbine blades in the turbo and "fight" the incoming air in the air flow meter (AFM)..............and results in the flutter sound............NOT good for the air flow meter
Have you got another dump valve to check to see if your current one is faulty?
and how long has it been doing this?
Biz is offline
Old 13-08-2006   #9
Trader Rating: (0)
i have waiste gate make spig noise ( not tssssss) i thought the d/v goes on that big turbo hose where mine is blanked i will post photos 2morrow.
wat is better w/g or d/v
Old 14-08-2006   #10
Trader Rating: (0)
New Zealand
"i have waiste gate make spig noise" What the F%^& does that mean? Its a wastegate anwyay. You have both a wastegate and dump valve from the factory.
SteveNZ is offline
Old 14-08-2006   #11
Trader Rating: (0)
i meant pigeon noise .
where is the d/v located
Old 15-08-2006   #12
alexGS's Avatar
Trader Rating: (1)
'd/v' is a T-fitting on the side of the large air pipe going into the turbocharger. Look down behind the airflow meter. Or look on the vertical metal pipe at the front of the engine - the uppermost pipe goes off to the right, around the corner, and into the 'd/v'.
-Alex
alexGS is offline
Old 20-08-2006   #13
Trader Rating: (0)
im sure i dont have a d/v i have the t piece but it is blocked of think i just got a waiste gate
so can i run both d/v + w/g ?
then the noise would go tssss pigeon ?
is the any difference in performance wise between the 2 or just the noise ?
Old 20-08-2006   #14
Trader Rating: (0)
this is my engine
Name:	my engine.JPG
Old 20-08-2006   #15
Trader Rating: (0)
New Zealand
<<<then the noise would go tssss pigeon >>
No, The whole point of the DV is to remove this noise. If you want the noise, leave the DV off the car.
The noise is compressor surge which is not very good for the turbo.
The wastegate is not at all part of this.
SteveNZ is offline
Dump Valve 1.9 Td Tipo calvins_tipo Tipo 10 10-09-2006 00:31
(T) hi im new which dump valve? lol bez440 Punto 3 12-04-2006 21:16
dump valve punto puntobloke Spotted / Was It You? 5 14-04-2005 23:47
Fake dump valve? SpongeBobSquareCar Lets Talk FIAT 45 19-10-2004 23:45
(G) Dump Valve Probs Dunc Maclean Uno 2 06-07-2004 04:42
