The FIAT Forum
Old 06-08-2006   #1
Trader Rating: (0)
increase boost????????
have just fitted bleed valve on mk2ut even when fully open still boosting as though standard,where is the max pressure switch and what does it look like ple,pics would be great,first ut i had lol
dspadge is offline
Old 06-08-2006   #2
Funny saying here
jamie86's Avatar
Trader Rating: (1)
jamie86 has donated! United Kingdom
Re: increase boost????????
As you look at the block straight on it's on the top left hand side little rubber/plastic bbot with two wires just tape them up... will try find a pic
ALSO GET THE FUELLING CHECKED
otherwise melted pistons are not fun trust me
EDIT: Here's a quick pic
Name:	boost sensor.jpg
Originally Posted by A wise person
Mini invented the giant killer, VW started the genre, Ford & Vauxhall Desecrated it, but the Peugeot 205 GTi was undoubtedly the king of the breed.
jamie86 is offline
Old 06-08-2006   #3
Trader Rating: (0)
have tried thatwires taped together touching,but still the same,same boost as standard,no faster still same place on boost gauge about 3/4 way round no way near the red??? have gas flowed head,dumpvalve k&n and full stainless fitted ??? first ut though
dspadge is offline
Old 06-08-2006   #4
Funny saying here
jamie86's Avatar
Trader Rating: (1)
What happens does it seem to cut back if you know what I mean?
jamie86 is offline
Old 06-08-2006   #5
Trader Rating: (0)
no still drives exactly the same as before bleed valve was fitted,when fully closed only 1/2 boosts fully open as though its not there,revs alway to 7000rpm still,3 way bleed valve fitted had to block 1 off T the two across blew through constantly when closed made no difference blocked 1 off and using the down piece and 1 across if that makes sense lol
dspadge is offline
Old 06-08-2006   #6
Funny saying here
jamie86's Avatar
Trader Rating: (1)
checked things like boost pipes no leaks etc?
jamie86 is offline
Old 06-08-2006   #7
Trader Rating: (0)
yes all pipes are ok nothing leaking just wont increase the boost,could the bleed valve be faulty???? brand new never fitted until tonight,cost 30 quid
dspadge is offline
Old 07-08-2006   #8
Trader Rating: (0)
New Zealand
Bleed valve faulty or not fitted correctly
SteveNZ is offline
(T) higher boost + higher compression ratio arc Cinquecento / Seicento 2 07-04-2006 18:57
(T) Turbo exhaust design theory by Garrett. J333EVO Cinquecento / Seicento 28 08-11-2005 00:55
(T) 1242 High boost turbo? Randomman Cinquecento / Seicento 25 29-10-2005 16:40
Boost gauge andybtsn Lets Talk FIAT 0 24-05-2005 12:44
Re-maps/ Chips/ Boost gauge kenny f Coupe 2 17-05-2004 20:18
