The FIAT Forum
Old 06-02-2004   #1
Trader Rating: (0)
Tempremental Git
Have a 1.0 litre ie Hobby which runs OK but not great, but always stalls on idle and is difficult to start half the time. It's had a reconditioned engine control unit and new distributor pickup.
I've narrowed the problem down to either the transisitor pack on the distributor, or the coil, which has a lower dc resistance than that quoted in the Haynes manual.
Anyone got any comments/suggestions?
Arthur is offline
Old 06-02-2004   #2
Banned
Trader Rating: (2)
Bushboy has donated!
i had a similar problem for a while... turned out i put in super unleaded instead of premium and my uno didnt like it much :p
sorry... this doesnt help much
Uno "Fire" 999cc
Lowered 40mm Uprated Gmax shock & Spring system
Fox Evo3 15" Alloy Wheels
3" Rage Backbox
Corbeau Clubmans
E-Tech hatch Spoiler (FOR SALE, PM ME!)
450W 12" Boschmann Sub
330W Pioneer 6x9s
500W SPLX Amp
Click here for photos
Bushboy is offline
Old 06-02-2004   #3
The Negotiator's Avatar
Trader Rating: (0)
The Negotiator has donated! United Kingdom
I believe i solved my problem (which seems very similar, rough running then stalling at idle - although mine had no problem starting i don't think) by replacing the vacuum advance unit. Maybe it will help.
Otherwise:
Was told before my problem could be lambda
Dirty throttle body
Dodgy plugs
Dodgy fuel filter
Regards
Paul
The Negotiator is offline
Old 17-02-2004   #4
Trader Rating: (0)
You could always adjust the idle throttle to make it run slightly smoother when not pressing at all on the pedal.
Yours,
Andy Bellenie
DotSPF is offline
Old 17-02-2004   #5
Trader Rating: (0)
Idling speed, I should say.
Yours,
Andy Bellenie
DotSPF is offline
Old 17-02-2004   #6
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
If it's an MkII with injection you don't have an idle speed adjuster. Make sure you don't adjust (tighten) the throttle cable so it doesn't strike the idling sensor. Makes the engine get too much fuel during idling and hence, stalls. A good clean of the injection unit might help.
Morten.
abarth alloys, steering wheel. inter alloy lowering. phoenix gold audio. refurnish.
projects: induction. seats. exhaust. tinting.
Morty Mort is offline
Old 17-02-2004   #7
Principality Retained :)
Trader Rating: (3)
arseofbox has donated! United Kingdom
Without attempting to Hijack-
My 899 Cinq did the same, it was due to petrol fouling the MAP Sensor line...
You'd need to get an adaption kit (part from a FIRE Engine) to solve it...
Tom (AofB)
Pedal to the metal? ....My Gearbox is on the floor!!!
arseofbox is offline
(T) Induction Kit Custard Rocket Cinquecento / Seicento 3 04-01-2004 21:19
