The FIAT Forum
Old 26-07-2006   #1
Trader Rating: (0)
braking problem
hi there
ive got a problem or two with my 94 uno 999 fire.
since it hit a large pothole a couple of weeks ago, theres been a bit of brake squeal and the brakes have been sticking on and off. the car will get to 30, struggle at that speed then shazam! the brakes release and i head towards the windscreen.
the squealing and sticking have been the same until today, the sqealing has got more consistent, with a hint of rattling. braking now sounds as if theres a traffic cone being dragged under the car, and they're undoubtely less effective (about 50%)
any ideas? btw, i have a notorious uno handbrake which i've tightened a while back (before pothole day) but is still loose
cheers
bazNICHOLS is offline
Old 26-07-2006   #2
oh me gums!
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: braking problem
1st of all your mad to have continued driving like this.
i would get the wheels off and inspect the brakes as it sounds like a loose caliper/pad
handbrake may need new shoes and have no adjustment left
custard is offline
Old 26-07-2006   #3
Banned
gt3man's Avatar
Trader Rating: (0)
gt3man has donated! United Kingdom
Re: braking problem
can you smell what this guys cookin.... his brakes
gt3man is offline
Old 26-07-2006   #4
Trader Rating: (0)
Re: braking problem
mad.....possibly
poor student....yes
mechanically minded....not really
i'm gonna take a look tomorrow and see what i see, any further suggestions appreciated
Old 26-07-2006   #5
Banned
gt3man's Avatar
Trader Rating: (0)
Re: braking problem
Originally Posted by bazNICHOLS
mad.....possibly
poor student....yes
Its possible you may have bent any number of things if you hit the pot hole real bad and buckled the wheel . You need to know which break is sticking And follow a process of elimination good luck
gt3man is offline
Old 27-07-2006   #6
Classic Uno Obsessive
1986Uno45S's Avatar
Trader Rating: (0)
Drives:
1986Uno45S has donated! United Kingdom
Re: braking problem
One possible answer is that the brake dust shield (the metal backing plate) has rusted through and the pothole has broken it off its mountings. This happend to my Uno a short while ago, and it left the the dust shield rattling around. I got all sorts of knocks and grinding noises, though it didn't affect the braking.
To solve it, I took the wheel off and pulled the remains of the backing plate off on both sides. End of problem!
What might be happening with your Uno is that the backing plate has intermintently got caught between the disk and the brake pad causing your problems.
As this is a safety issue I'd get it looked at IMMEDIATELY. Driving with dodgy brakes is a definite no no. Fingers crossed it will be something simple and you'll be motoring on your way again.
Let the forum know how you get on, and any other queries feel free to ask
Chas
Originally Posted by Trinity View Post
we got a lot 126 here in Egypt .. a funny car and fun to drive though sometimes i feel like I am sitting on a chair in the middle of the street
http://onastick.net/drew/sinistar/
1986Uno45S is offline
Old 27-07-2006   #7
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
Re: braking problem
While Chas' explanation is a very good one, I also wonder if the hitting-a-pothole was a mere coincidence given that you have also had handbrake issues - I personally suspect that the rear shoes are completely worn out, 'grabbing' (self-locking-on), and giving metal-to-metal contact.
Because the shoe lining wears in a wedge shape, what sometimes happens is that the lining detaches from the shoe and jams itself between the other shoe and the drum - dramatic when it happened to me in an old 128, basically the brake locks on and doesn't come off again! Although this isn't quite what you have, I still wonder if yours could be some variation on this theme.
I agree with the others - DON'T drive the car until you have the brakes sorted - it's just not worth the risks (unpredictable failure giving damage to your car, you, and other people around you and their property, to say nothing of the inconvenience and COSTS...)
But having said all that, it's simple to investigate yourself. Check the front brakes and their dust shields, as Chas says. If using the car's own jack to remove the wheels, don't crawl under the car when raised - you should be able to see/do all you need to from beside the car, even changing the pads is not difficult.
Remove each rear wheel and use a 12mm spanner to remove the two bolts (one 'special' with a long pin sticking out) that secure the rear drum. With the handbrake off, the drum should pull off fairly easily (if not, try striking the flat part in the centre of the drum as though you were trying to knock it 'on', the vibration will loosen the rust, aided by a few squirts of WD40 around the centre hub.)
With the drum off, you are looking for the thickness of the brake shoe lining (the material attached to the steel backing) - needs to be at least 2mm thick in my opinion, as this thickness will last at least a year till the next check.
Perhaps consider referring to a Haynes manual - try http://www.unoturbo.za.net/ for a download - as Haynes does a good job of explaining jobs like working on the brakes. You don't need many tools and the parts (from a general clutch/brake shop) are good value considering their importance and lifespan. But you need to do a careful and thorough job, and if in doubt about any part, please seek a second opinion in person (or perhaps post pictures to the forum!)
Thanks,
-Alex
PS Nice description of the sound ("like a traffic cone being dragged under the car", raised a smile as I wonder how you know what this sounds like )
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 27-07-2006   #8
SuperUno's Avatar
Trader Rating: (1)
Re: braking problem
Sooo. off topic, but on the last stage rally i did i was cutting a corner a bit too much and dragged a cone about 1/2 a mile, so i know what that sounds like as well.
Back on topic, i would also say don't drive till its sorted, check out what Chas and Alex have said it can't be much else.
SuperUno is offline
Old 27-07-2006   #9
Trader Rating: (0)
Re: braking problem
thanks for the advice, i'm off for a look now (its parked outside my girlfriends house at the mo)
i'll let you know how i get on
baz
Old 27-07-2006   #10
1986Uno45S's Avatar
Trader Rating: (0)
Drives:
Re: braking problem
One other helpful pieces of advice when jacking a car, whether it is with the supplied jack, trolley jack and even when using axle stands is to do the following:
With the wheel off, place it under the front suspension arm locating points or chassis rail on the side of the car you're working on. If the jack/ axle stand fails, you'll still have some means of stopping the car from crashing straight to the ground.
Whenever I work on a car with a wheel off, I always leave the car on axle stands, with the trolley jack just supporting some weight AND the removed wheel underneath a load bearing point. This gives three means of stopping the car from collapsing and squashing you in the process
Old 28-07-2006   #11
Banned
gt3man's Avatar
Trader Rating: (0)
Re: braking problem
I don't like Axel stands i use some good breeze blocks
gt3man is offline
Old 28-07-2006   #12
1986Uno45S's Avatar
Trader Rating: (0)
Drives:
Re: braking problem
Concrete breeze blocks????
Noooooooooooo! NEVER use bricks or concrete breeze blocks as they can crumble under the weight of a car. Axle stands are fine if used correctly, though as mentioned I always use back up support when working under a car.
You can't be too careful...
Old 28-07-2006   #13
Banned
gt3man's Avatar
Trader Rating: (0)
Re: braking problem
did you not see i said "good"
gt3man is offline
Old 29-07-2006   #14
1986Uno45S's Avatar
Trader Rating: (0)
Drives:
Re: braking problem
Good or not, I'd never use concrete to support a car! All the warning advice I've read over the years says 'no!'. However, as secondary means to support a car (i.e as a back up measure for axle stands failing) they're ok, but I'd always use substanial axle stands as the primary means. You can't be too careful when working underneath a car
Old 29-07-2006   #15
Banned
gt3man's Avatar
Trader Rating: (0)
Re: braking problem
Sure Axel stands are what they are made for. Personally i have never used them so i cant comment on there stability. I'm sure there are a few variations of stand on the market, some better than others I would guess. However if I was working on a car using support other than ramps. I would stick to my blocks, as I can get more contact surface area out of these to the car, than any stand. So in theory more support and less chance of a failure
note..... (my car is lightweight and the position I have used them in, in the past has been flat to the car & low to the ground. It maybe dangerous or, otherwise for people to use this method of support. This is what i do myself for my own application)
gt3man is offline
(T) Solution to Punto 75 mk1 Engine Problem Tziallas Punto 4 24-03-2008 18:35
(G) Punto 3 door seat problem Reaver23 Punto 4 04-09-2007 12:03
(T) Injector Problem! Help! Thanks fear Bravo / Brava 4 19-11-2006 20:11
(T) Windscreen wiper motor problem Thomas P Uno 10 23-08-2006 20:04
Mid-throttle injection problem in Lancia Y10 FatNote Panda (Classic) 26 30-07-2004 18:58
