The FIAT Forum
Old 13-07-2006   #1
Trader Rating: (0)
Driver's window
My window keeps falling down into the door casing. Its quite easy to fix but keeps happening. Has anyone else had this problem and what can I do to fix it permanently?
Thanks.
JacquieC is offline
Old 13-07-2006   #2
Jai
BLUES+TWOS! PANDA+UNO!
Jai's Avatar
Trader Rating: (6)
Jai has donated! United Kingdom
Re: Driver's window
sounds like the little plastic "winged" bolt thingy holding the pane on to the runner has snapped,
will need to take of the door card (easy, just undo all screws around door handle, and lower pocket, pop off door lever srround, and ease away from door) then there should be a membrane over the metal frame, peel that off, and the window mechanism should be exposed.
be careful here, the metal door frame is quite sharp, and cuts are easy to get
wind down the window so you can see the horzontal bit the glass pane rests on, in the middle should be a white plastic plug, on the other side should feel the 2 wings popping out, holding it in place. the pane should be a tight fit into the runner it rests on, and can be hard to move.
if the plug is broken, pop it out, replace with another one (should be pennies from a dealer/scrappy) and replace all the door trim
voila! btw this worked on my tub with electric window, feel free to modify for non tub windups
The moderator formerly known as Turboned
People, staff meeting has been cancelled. You all have one goal today: to get Vincent Chase’s brother, Johnny Chase, a job. Any job! I don’t care if it’s a porn shoot in which he is being gang raped by a gaggle of silverback apes, if there are cameras rolling, everybody wins. 10 grand for anyone that can deliver this to me, today.
Jai is offline
Old 13-07-2006   #3
Trader Rating: (0)
Re: Driver's window
Thanks for that. Printing out your reply and will go see what the score is.
Jacquie
JacquieC is offline
Old 13-07-2006   #4
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
Re: Driver's window
Since I couldn't get the replacement part that Turboned mentioned (winged plastic piece) I just drilled a small hole through the plastic protrusion through the outside of the glass, and put a split-pin through.
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 13-07-2006   #5
jjhepburn's Avatar
Trader Rating: (0)
New Zealand
Re: Driver's window
I agree with Alex's sugestion. Thats how I have always fixed that problem. Has the side effect of making the window easier to remove since those plastic clips are a pain in the ass to undo (without cutting yourself on the door).
One modification to Alex's plan is to use R clips (I think thats what they are called, they have a straight pin with a curly bit that holds it in place).
Current: 1987 Uno (1580cc), 1996 Bravo SX, 1990 mk1 Uno 45,and a 1973 Mini 850
Old: 1994 Punto 90ELX, 1984 Uno 70S, 1989 Uno 70SL, 1988 Uno 70SL, 1986 Uno 45 FIRE, 1987 Uno 45 FIRE, 1987 Uno 45 FIRE, 1989 Uno 45 FIRE, 1989 Suzuki FA50, and a 1980 Mini 1000
jjhepburn is offline
Old 14-07-2006   #6
(CZ)enda's Avatar
Trader Rating: (0)
Czech Republic
Re: Driver's window
It is also useful to wind some self-vulcanizing rubber tape (hope it makes sense - a tape that is not very sticky when applied, but hardens to solid rubber. I believe its primary application is waterproof sealing and insulation of electric HV cables) between the glass and the pin. It reduces the crashing noise when you close the door.
(CZ)enda is offline
Old 14-07-2006   #7
alexGS's Avatar
Trader Rating: (1)
Re: Driver's window
That's a top tip, (CZ)enda! I hate that crashing noise, always sounds like the glass has fallen off (of course, it did - one day!)
-Alex
alexGS is offline
Old 14-07-2006   #8
Jai
Jai's Avatar
Trader Rating: (6)
Re: Driver's window
yeah that smashing sound and glass tinkling to the ground, and inside the door, is one i hope never to hear again.......
Jai is offline
Die Hard!!! The Negotiator Leisure Lounge 27 24-04-2006 22:20
SEI drivers window needed urgent, north east london/ surrounding essex area! Bushboy Leisure Lounge 2 23-03-2006 18:25
Driver's side window Nudgeman Bodyshop 4 30-11-2005 14:37
(T) Marea ELX Driver's Electric Window Stuck OilBurner Marea 2 04-08-2005 01:31
(G) drivers window jennione Marea 3 14-01-2004 02:37
