The FIAT Forum
Old 12-07-2006   #1
ECL
Trader Rating: (0)
South Africa
Broken Conrod
Does anybody have any experience with an Uno Turbo braking a conrod? What was the reason?
ECL is offline
Old 12-07-2006   #2
oh me gums!
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: Broken Conrod
what sort of boost/mods were/are you running
custard is offline
Old 13-07-2006   #3
ECL
Trader Rating: (0)
South Africa
Re: Broken Conrod
I am looking at 2+ bar boost and 1.5 bar with NOS. BB GT2860R turbo. Mods on the block, peen shot conrods, balancing all relevant parts, lightened flywheel, bigger intercooler and oil cooler, Weiseco pistons, gasflowed head with head stud kit, custom cam, EFI with 550cc injectors and 76mm exhaust.
My concern is that with all the time and money spend I would put a conrod through the block and mess it all up with 2 high boost. Maybe there is somebody with experience that would help me out.
ECL is offline
Old 13-07-2006   #4
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
Re: Broken Conrod
Well, I have plenty of experience with NOT breaking con-rods on FIAT engines
I believe a main cause of this problem would be excessive bearing clearance/crankpins worn oval. With the amount of effort going into rebuilding that engine, it shouldn't be too much to measure the crankpins carefully in two directions and ensure that replacement bearing shells are the correct size, fitted in conditions of absolute cleanliness.
My pretty-much standard Uno Turbo engine develops peak power at somewhere less than 6000RPM. It's easy with a turbocharged engine to run well past peak power. I'd suggest an observed rev limit of 8000RPM unless you have had all the rotating parts balanced. Note that as standard, FIAT engines are well-balanced, so you have to be certain that your 'expert' balancer is not likely to make things worse!
Just my thoughts. You really have little to fear; blowing the head gasket is a far more likely possibility at those boost levels.
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 13-07-2006   #5
Biz
The Big-Indecisive-Zebra!
Biz's Avatar
Trader Rating: (2)
Biz has donated! United Kingdom
Re: Broken Conrod
This is what could possibily make it throw a rod:
Detination (Like how a diesel engine works, compression ignition)
pre-ignition (a hot spark plug electrode, coke build up, incorrect ignition timing, these factors will ignite the fuel before the spark plug does)
Caused by
1) Ignition timing and the octane of the fuel that is used
2) Cokeing up of the combustion chamber (Hot spots, valve not seating properly, etc, etc)
The piston could be coming up on the compression stroke and the air/fuel mixutre is ignited before the spark plug ignites and that will put MASSIVE forces on the connecting rods but the big-end shells SHOULD take the force as they will "crush" under the stress but pro-longed detenation or pre-ignition will kill a rod(s)
Any clearnces will promote a knocking sound a the engine should be used at all if there is any knocking sounds
Torque wins races and puts people in their places!!!
From B a r r y boys: "A mate of mine had an Uno turbo donkeys years ago. It was a bloody rapid little thing, but about as refined as sitting in a washing machine full of nails on full spin. Great fun though."
Biz is offline
Old 19-07-2006   #6
Trader Rating: (0)
New Zealand
Re: Broken Conrod
Never heard of a broken UT rod. However use the 1300 rods, not 1400. 1300 are forged, 1400 are generally cast.
SteveNZ is offline
Old 19-07-2006   #7
ECL
Trader Rating: (0)
South Africa
Re: Broken Conrod
I unfortunately dont have access to 1300 conrods. There are very few 1300 in SA.
Thanks for all the advice guys. I feel much better knowing that the sub assembly is fine.
ECL is offline
Old 19-07-2006   #8
Trader Rating: (0)
New Zealand
Re: Broken Conrod
1500 rods are the same as 1300T
SteveNZ is offline
Old 19-07-2006   #9
ECL
Trader Rating: (0)
South Africa
Re: Broken Conrod
Is that the X19 conrods?
ECL is offline
Old 21-07-2006   #10
Trader Rating: (0)
New Zealand
Re: Broken Conrod
yes
SteveNZ is offline
(T) Broken front spring timr69 Stilo 18 11-10-2006 19:54
(G) How does a broken horn cost you £200? Seraph Stilo 4 14-02-2006 01:57
(T) Broken Wheel Bolt KCF Punto 22 10-09-2005 13:32
Broken choke cable... Martiny10 Panda (Classic) 3 03-03-2005 23:18
(G) Removing A Broken Alloy Wheel Nut Aziz Punto 10 15-05-2004 03:24
