The FIAT Forum
Old 20-06-2006   #1
Drinu's Avatar
Trader Rating: (0)
how do I fix this!?(pic included)
Hey guys,
I have a piece of plastic below the dashboard on the drivers side which is bent (see pic). It seems the previous owner just bent it out of shape to get to the speaker in the dashboard. Do you know how I can bend it back to shape as it really buggin me!
Mods:
Clear indicators
GT Auto Alarm
White dials
Autometer Rev-counter
Boot light
Alloy wheels 185/55 R14
Sprayed Disc brakes
x2 8" rear speakers
x2 4" front speakers
Kenwood CD player
Drinu is offline
Old 20-06-2006   #2
meow
beau's Avatar
Trader Rating: (16)
beau has donated! United Kingdom
Re: how do I fix this!?(pic included)
circle it in red im not 100% what you want
1993 Uno Turbo / 1995 Punto 55 / 2000 Punto JTD
1998 Punto Sporting / 1993 Ford Escort 1800 16v / 1998 Fiat Bravo HLX
beau is offline
Old 20-06-2006   #3
Drinu's Avatar
Trader Rating: (0)
here you go!!
Mods:
Clear indicators
GT Auto Alarm
White dials
Boot light
Sprayed Disc brakes
x2 8" rear speakers
Kenwood CD player
Drinu is offline
Old 20-06-2006   #4
meow
beau's Avatar
Trader Rating: (16)
hmmm knows what that is, so why doesnt it bend back? is it too solid? or does it move back but then go back to that position?
beau is offline
Old 20-06-2006   #5
Trader Rating: (7)
Suriname
Should be a little clip just under the dash on the right that it sits on.
Otherwise cant you just bend it by hand, its only secured by one nut under the steering column (and one bolt in the clutch pedal footrest if youve got one)
chrisunoman is offline
Old 20-06-2006   #6
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
I think you'll find that it is not so much bent as much as 'naturally distorted'. i.e. it may have gone like that by itself rather than because someone bent it.
It's a rather large unsupported piece of tough plastic IIRC, tucked under at the corner and a screw in the centre. What I would do is glue a piece of aluminium (or steel) strip to the back, with hot glue or (ideally) epoxy resin, and then you will be able to impart a shape to it (i.e. flat). Perforated strip like 'Meccano' as included with central locking kits (for example!) will work fine.
In theory you could heat the plastic with a hot air gun, and then flatten it. In practice this method usually ends in tears (yours when it gets too hot to touch, or when the edge melts). I've been down this road a few times before
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 20-06-2006   #7
Drinu's Avatar
Trader Rating: (0)
thanks guys,
bending it back into shape is for nothing...it just doesnt want to bend back...now I will try and heat it with a hair dryer and hold it in shape. Who knows maybe I can fix it.
AlexGS: your fix although works is more than I can handle!
THanks,
Will try this evening!
Mods:
Clear indicators
GT Auto Alarm
White dials
Boot light
Sprayed Disc brakes
x2 8" rear speakers
Kenwood CD player
Drinu is offline
Old 20-06-2006   #8
Blueno
tonyfurnell's Avatar
Trader Rating: (0)
tonyfurnell has donated! United Kingdom
Hey Drinu, mine's exactly the same -- I'd say Alex's suggestion would be most likely to succeed, just a makeshift tab of almost any solid material, glued to the top side of the bent piece, which can then be tucked behind the speaker panel and will hold in place fine.
Good luck with bending if you go for it though!
Tony
furnellmusic.com
myspace.com/furnellmusic
tonyfurnell is offline
Old 20-06-2006   #9
Trader Rating: (0)
well u seem to like gages so bye a gauge u like the with monting bracket screw it up with self tapers straight throung the plastick into the plastick above it it will hold it up plus ull have enouther gauge
brava_clay is offline
Old 20-06-2006   #10
Trader Rating: (7)
Suriname
Does that last post make no sense to anyone else???
When people cant write in English or even vaguely spell correctly then dont bother at all!
Old 21-06-2006   #11
alexGS's Avatar
Trader Rating: (1)
possibly a little harsh chrisunoman...
I figured it out, but I wonder if any typing really was saved (e.g. 'bye' is the same length as 'buy'.) Good idea anyway - maybe an oil pressure gauge could be added there? Not sure if there is any plastic above the trim panel, so there could still be a need for a metal bracket.
The idea of sticking a metal strip to the back was mainly to make it pliable - so that bending the steel would hold the plastic in shape - but of course making an extra mounting bracket is good as well.
-Alex
alexGS is offline
Old 21-06-2006   #12
Classic Uno Obsessive
1986Uno45S's Avatar
Trader Rating: (0)
Drives:
1986Uno45S has donated! United Kingdom
And this is even more so when they are English and have no excuse for not writing their own language properly. It's one thing being a dunce at English, but quite another to show no shame and broadcast it to everyone
Do very few people take pride in how their writing comes across to others these days I have to agree with Chris in that those who can't even take the time to check they've written legibly really shouldn't bother...
1986Uno45S is offline
Old 21-06-2006   #13
Trader Rating: (0)
Well I think you to are 4ss h0l3s and should take the time to realise that.
Old 21-06-2006   #14
Trader Rating: (7)
Suriname
HTML Code:
Your the only ARSE HOLE around here!
I can say anything!
Oh, and its 'you two' not 'you to'.
Old 21-06-2006   #15
1986Uno45S's Avatar
Trader Rating: (0)
Drives:
I guess you never did get English at GCSE level!
(T) So how do i fix this then.... GhostWKD Cinquecento / Seicento 36 07-12-2005 21:40
(S) Front Bumper damaged, how to fix softwarez Punto 5 10-11-2005 22:12
(G) 92 Uno Radiator burst, car overheated should I fix? phewerd Uno 9 14-05-2005 15:09
(G) FIATsaid they WILL fix the piston slap at last!!!!!!!!! nagoodch Punto 1 23-11-2004 20:44
(G) Cheap fix if new backbox is out of the question syphon123 Cinquecento / Seicento 8 01-05-2003 03:29
