The FIAT Forum
Old 11-06-2006   #1
MG ZR Owner :)
SkinzCinqSporting's Avatar
Trader Rating: (2)
SkinzCinqSporting has donated!
Ignition Barrel
I have a friend whose looking at buying a 1 litre Uno for the princely sum of £150. Only problem is it needs a new ignition barrel and I wasn't sure if Uno's have coded keys like my Cinq. So could he just put any Uno ignition barrel on or not? Obviously he'll have separate keys to the doors though.
SkinzCinqSporting is offline
Old 11-06-2006   #2
oh me gums!
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: Ignition Barrel
nah no coding
custard is offline
Old 11-06-2006   #3
MG ZR Owner :)
Trader Rating: (2)
Re: Ignition Barrel
Cheers custard, I'll tell him any Uno one will do then
Old 12-06-2006   #4
Classic Uno Obsessive
1986Uno45S's Avatar
Trader Rating: (0)
Drives:
1986Uno45S has donated! United Kingdom
Re: Ignition Barrel
Yup, Custard is right. No hi tech stuff like coded keys on an old skool Uno!
Not sure how easy it is to change the lock barrel. If it's awkward, you can swap the whole steering column over with one with a good barrel already attached.
By the way, is it the barrel that is the problem or the switch itself? If it's the switch then that is dead easy to change and your mate could still use the original barrel and key
1986Uno45S is offline
Old 12-06-2006   #5
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
Re: Ignition Barrel
Also, sometimes it is just the key that wears and jams. You may find that a new cut key will work OK in the original lock. That happened with my Mum's Uno.
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 16-06-2006   #6
MG ZR Owner :)
Trader Rating: (2)
Re: Ignition Barrel
I haven't looked yet, but apparently he has bought it. It doesn't start due to the key not turning in the ignition so who knows, like I said, haven't looked myself yet. But this lad is worse off financially than me, so trying loads of things just isn't economical.
(T) Ignition barrel problems matt_chase Bravo / Brava 4 28-12-2005 17:27
Ignition barrel fitting seanory1 Coupe 2 23-08-2005 22:53
(T) Remove Ignition Barrel from Switch Eiteews Cinquecento / Seicento 2 06-08-2005 01:35
ignition barrel removal no key, dave Leisure Lounge 20 26-05-2005 22:23
