The FIAT Forum
Old 22-01-2004   #1
Moderator
Trader Rating: (7)
Steven has donated!
Uno - water in the footwell
I'm baffled.
My Uno is currently off the road. I start it every night and run it up to temperature.
Recently I've noticed that there is water in the drivers footwell. I've had the seats and carpet out and the body and floor is solid, so it's not getting in through a crack or hole. The heater matrix is disconnected in the engine bay, so it's not that.
It's not being driven in the wet, so water can't get in that way. It is on the drive and water is getting in somehow.
Are there any drainage points I'm missing? Any ideas anyone? Thanks in advance.
<h5>Click here for pictures of my Uno
Click here for pictures of my Brava
Steven is offline
Old 22-01-2004   #2
Donz's Avatar
Trader Rating: (0)
Donz has donated!
i'd check the seal around the door, if the car isn't going anywhere, then it must be rain getting in somewhere...
- - Donz - -
Donz is offline
Old 22-01-2004   #3
Trader Rating: (0)
yeah check the rubber seal cos my is falling off and if its been raining wen i open to door a lot of water ends up on my seat and geting my bottom wet!
gotta love the uno's
Spam0r is offline
Old 22-01-2004   #4
Donz's Avatar
Trader Rating: (0)
Donz has donated!
did we need that much detail?
- - Donz - -
Donz is offline
Old 22-01-2004   #5
Moderator
Trader Rating: (7)
Steven has donated!
The more detail the better.
Thanks folks, but I've checked the seal and it seems 100%. I think it's more likely to be a blocked drain or something.
Steven is offline
Old 22-01-2004   #6
Trader Rating: (0)
- - Donz - -
At least there wasn't a picture [:o)]
John H is offline
Old 22-01-2004   #7
Banned
Trader Rating: (2)
Bushboy has donated!
i suppose ull just have to check everywhere for holes.. check the rubber on the rear windows. Mine leak in heavy rain slightly (or when im powerwashing it) cause they dont close tight enough. worth a check
Uno "Fire" 999cc
Lowered 40mm Uprated Gmax shock & Spring system
Fox Evo3 15" Alloy Wheels
3" Rage Backbox
Corbeau Clubmans
E-Tech hatch Spoiler
2x 450W 12" Custom Built Bass Box
800W 6x9s
300W & 500W Amps
Click here for photos
Bushboy is offline
Old 22-01-2004   #8
Trader Rating: (0)
lol check for it leaking threw the holes in the bulkhead!
Spam0r is offline
Old 22-01-2004   #9
Donz's Avatar
Trader Rating: (0)
Donz has donated!
there might still be drips coming from spam0r's butt, this could also cause it...
- - Donz - -
Donz is offline
Old 23-01-2004   #10
The Negotiator's Avatar
Trader Rating: (0)
The Negotiator has donated! United Kingdom
Does it have a sunroof?
The Negotiator is offline
Old 23-01-2004   #11
Moderator
Trader Rating: (7)
Steven has donated!
Steven is offline
Old 23-01-2004   #12
Trader Rating: (0)
Only thing i can offer has already been tried. I had a slight leak in heavy rain from the seal around the door. Fixed by just opening it out a little with my fingers. In worse case water could get in on the edge of the door and be channeled down to the footwell.
SOrry can't help more. I only offered sunroof idea as some seem to have a pipe leading down in that direction and they often get blocked.
Best of luck finding out the problem. My girlfriends Rover 100 has a leak in the footwell (passenger) so if you think the fix will be relevant to that I would appriciate any info.
Rgds
Paul
Old 23-01-2004   #13
Banned
Trader Rating: (2)
maybe someone poured a bucket of water in it by accident and didnt tell u cause ude get angry
Uno "Fire" 999cc
3" Rage Backbox
Corbeau Clubmans
800W 6x9s
300W & 500W Amps
Bushboy is offline
Old 23-01-2004   #14
Donz's Avatar
Trader Rating: (0)
Donz has donated!
in an attempt to find where it is coming from, you could dry it out, then put newspaper down, give it 30mins of rain and go see where is wet....
- - Donz - -
Donz is offline
Old 23-01-2004   #15
Moderator
Trader Rating: (7)
Steven has donated!
Cheers for the suggestions folks. I try and find it again this weekend. Thats a good idea Donz. :)
Steven is offline
(G) Water in footwell Morty Mort Uno 6 20-07-2004 18:20
(T) Water ingress to driver's footwell, Punto meirion Punto 5 19-05-2004 04:18
(G) Water ingress to driver's footwell meirion Punto 3 15-03-2004 05:55
(T) Water leak into drivers footwell edmoff Punto 8 26-01-2004 22:32
(T) water in footwell glynnoss Punto 5 24-09-2003 01:49
