| Microplex switch??? I've heard taht there is acctualy a microplex unit which can support over 1bar of boost. Is it true? Is it MED604C unit? I have MED402, how good is it? Please help! P.S.Sorry on my bad English, I'm from Serbia....
| Re: Microplex switch??? Uno turbo is mapped to 1.5 bar boost
| | #3 | ||
| Re: Microplex switch??? Are you sure? Cause if its true that would be great. So...only problem is that injectors are too small and head gasket is to weak right? I've got one question about LE2-Jetronic fuel injection on uno turbo mk1. Is there any way to put bigger injectors(like those from mk2.) and to not have rich mixture on idle and low rpm? What do you think about extra 4injector operated by Link system wich have control of fuel enrichment,start point...?
| | #4 | ||||||||
What Link exactly? No point running 4 injectors. 1 larger one before the throttle body is just as effective.
| | 95-Cinq-899 | Cinquecento / Seicento | 8 | 21-02-2006 19:15 |
| | cm246 | Cinquecento / Seicento | 1 | 17-10-2005 22:36 |
| | simonyap | Bravo / Brava | 0 | 22-04-2005 09:19 |
| | coolhand_mike | Uno | 0 | 06-10-2004 23:58 |
| | DotSPF | Uno | 6 | 11-11-2003 23:18 |
