A_Acolyte
Hi chaps.
To cut a long story short, since installing these new front brake discs and front wheel-hubs I've got brake shudder. Its much more evident under heavier braking (which, with me, is pretty much allll the time), though it is very very mildly perceptible under normal braking. You can't feel it in a parking-lot.
I installed new brake-pads at the same time.
As per the instructions of the guys that installed it (Autoquip! Aaargh!), I've given it time to run-in (around 1000kms now perhaps), and its not any better - perhaps worse.
I believe a warped disc is the cause of it - am I right? Could it be anything else? I thought perhaps its the steering-rack or something, but if that were the case then I'd have had the problem before the new stuff was fitted too.
-Acolyte
-Acolyte
