The FIAT Forum
Old 13-03-2006   #1
meow
beau's Avatar
Trader Rating: (16)
beau has donated! United Kingdom
what do you unos start like??
well just started my car on a very cold night, not been started in ages (must be several months?), and was very impressed that it started first time on the turn of the key leaning in from the passenger side lol.
got me thinking, how does your car start? first turn on key? any revving needed like some old cars? even my sisters punto sometimes doesnt start until 2nd/3rd time lol
it seems my unos running very smoothly, especially seeing as it has no airbox lol, hmmm, probably shouldnt start it without them hoses connected lol
1993 Uno Turbo / 1995 Punto 55 / 2000 Punto JTD
1998 Punto Sporting / 1993 Ford Escort 1800 16v / 1998 Fiat Bravo HLX
beau is offline
Old 13-03-2006   #2
faster! FASTER!!!
Trader Rating: (2)
bulldog5046 has donated! United Kingdom
Re: what do you unos start like??
uno starts first flick of the key normally, somtimes i let go of the key just before it stars by accident lol.
the marea takes some time but it is only running 4 cyl
The first UK Marea Turbo?
bulldog5046 is offline
Old 14-03-2006   #3
Trader Rating: (0)
Thumbs up Re: what do you unos start like??
starts first time everytime
Fiat Punto Sporting ftw
coldfirejones is offline
Old 14-03-2006   #4
Classic Uno Obsessive
1986Uno45S's Avatar
Trader Rating: (0)
Drives:
1986Uno45S has donated! United Kingdom
I push the accelerator pedel down once to prime the carburetor (accelerator pump squirts petrol into the venturi when you do this), pull the choke out, and my Uno will start instantly
In the summer I don't even need the choke!
1986Uno45S is offline
Old 14-03-2006   #5
meow
beau's Avatar
Trader Rating: (16)
manual choke, these old cars :shakehead
beau is offline
Old 14-03-2006   #6
Muzzie's Avatar
Trader Rating: (0)
New Zealand
UT starts first time everytime. Wait a half a second for the fuel pump to prime and then starts straight up.
Im Not Dumb, Im Just Selectively Observant!!!
http://img17.exs.cx/img17/6424/redmustang1eo.gif
^^ Click Me ^^
Muzzie is offline
Old 14-03-2006   #7
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
I think, without an airbox, the engine would not start/idle quite as smoothly as it would with an airbox... ? Would be a bit lean...
My Uno Turbo starts very well cold, and pretty well hot, though not always instant, takes a second or so of cranking, possibly because the idle speed is a bit low. I find that with the engine running, the revs will 'stumble' on returning to idle (e.g. slowing down, foot on clutch, revs dip to 400RPM then recover to 900RPM). I think this also affects the starting. I suspect it might be a throttle-plate-setting issue.
Probably best then to follow the handbook instructions for carburettor Unos, which are to 'depress accelerator pedal slightly'. Never hurts!
I used to have an Uno 60 once upon a time (2000-2001) which was not so keen on restarting with the engine hot. I think the main cause was a broken heat shield (bakelight board under the Solex carburettor) causing the exhaust heat to reach the carburettor after engine-switch off. Petrol would burp out of the carburettor every ten seconds and into the engine (you could hear it if you listened carefully). This flooded the engine and I had to start it with the accelerator held fully-down (standard flood-clearing technique). I suspect that a slight lowering of the carb float level may have helped avoid the problem.
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 14-03-2006   #8
paz
Trader Rating: (0)
Mine starts even better in the cold than any other time - the only occasion its been slightly unhappy, is in the damp.
paz
paz is offline
Old 14-03-2006   #9
1986Uno45S's Avatar
Trader Rating: (0)
Drives:
ECU failure? What ECU failure?
There are some advantages of older cars
Old 16-03-2006   #10
Blueno
tonyfurnell's Avatar
Trader Rating: (0)
tonyfurnell has donated! United Kingdom
My mk2 1.0 starts a treat, hot or cold, with minimal turning over.
Although I did have some trouble with it when I left it standing in Belfast for 4 weeks over Christmas, with muchos cold weather, and tried to start it on a day when ice covered the car, inside and out(!).... ended up taking some severe pumping of the accelerator followed by ignition turning & further pumping.... repeating continuously over the next 20 minutes or so!!
Personally though I suspect the petrol that I filled up with from a dodgy garage towards Larne before Christmas...
Tony
furnellmusic.com
myspace.com/furnellmusic
tonyfurnell is offline
Old 16-03-2006   #11
Jai
BLUES+TWOS! PANDA+UNO!
Jai's Avatar
Trader Rating: (6)
Jai has donated! United Kingdom
when i had my last 70sx, i was away in india for six months, left it parked outside the house, told the family to start her at least once a week. of course on my return it was "well when we tried it wouldn't start so we left it" went outside, all levels were ok, second try fired right up, took her for a drive for about 30 mins, pumped the tyres a bit, job done.
the tub never failed to fired first time, she'd wait till i was miles from home, or in the middle of a major junction to throw a hissy fit......
The moderator formerly known as Turboned
People, staff meeting has been cancelled. You all have one goal today: to get Vincent Chase’s brother, Johnny Chase, a job. Any job! I don’t care if it’s a porn shoot in which he is being gang raped by a gaggle of silverback apes, if there are cameras rolling, everybody wins. 10 grand for anyone that can deliver this to me, today.
Jai is offline
Old 16-03-2006   #12
Trader Rating: (0)
Mine is a good starter, starts first time every time even after leaving it sitting for ages. I haven't left it standing for extremely long periods of time before (I think the longest was about 2 months) but it started up fine after that, and that was over the winter aswell.
PJB88 is offline
Engine Start Problem datasamm Newbie Central 3 10-01-2006 00:15
Car won't start Gentzen01 Panda (Classic) 10 09-04-2005 11:05
(T) I ran out of petrol and now my car wont start HELP!! res1492 Stilo 17 10-03-2005 11:26
(T) 75SX - Replaced sensor, but still won't start shabz1981 Punto 6 23-11-2004 00:05
(T) Help! 1995 M doesn't start! Martina Punto 18 16-11-2004 00:07
