The FIAT Forum
Old 26-11-2003   #1
mae
Trader Rating: (0)
Fiat Uno Fire running rough
[font=Arial]Hi - i have an '89 Fire which is starting to run rough. It has a manual choke, which I always need to use when starting. In the past my fire has run fine once the engine heated up. Increasingly though it cuts out when idling, and is jerky when driving under 60kph. It's booked in for a garage visit, but I wanted to check with other Fiat owners first, cos i'm sure someone else has had this problem and fixed it. I'm assuming my fire just needs a good tune - look forward to advice etc![/font=Arial]
mae is offline
Old 26-11-2003   #2
Enzo's Avatar
Trader Rating: (0)
Italy
I'd try first of all with a complete carburettor cleaning...especially if it's never been done;)!Then check you distributor inside, if it has points check their gap, it should be between those limits 0.38-0.47mm...if it's a breakerless one it should cut out when hot at any speed[xx(]...the parts probably to replace are the Hall sensor &/or the module bolted on the outer of the distibutor!Let's know how do you proceed:)!
Enzo is offline
Old 28-11-2003   #3
Trader Rating: (0)
Kiaora Kiwi
As Enzo says, a can of carb cleaner down the intake (with the air filter off) did wonders to my Fire....don't forget to soak up the excess and careful not to drop anything down there...:D
lashlondon is offline
Old 28-11-2003   #4
mae
Trader Rating: (0)
Cheers guys...will try your suggestions this weekend & let you know how I get on.
mae is offline
Discounted Tuning @ Fiat Forum Day alfanige Lets Talk FIAT 45 17-01-2006 15:03
MODELS FIAT SHOULD MAKE! jetweed Lets Talk FIAT 61 30-08-2004 21:38
(G) uno fire 1100 running very rough stash Uno 3 08-06-2004 11:57
fiat bravo running rough dj219957 Lets Talk FIAT 1 05-02-2004 04:26
(G) Fiat Bravo (moved thread) sonia cachia Bravo / Brava 7 20-10-2003 04:30
