Thread Tools
Old 3 Weeks Ago   #1
New Zealand
Front Wipers not returning to start position
Hey everyone,
Just a note to start - This is a 1989 Uno Fire 45
Recently about a week ago my front wipers stopped working. After a week of checking connections, the motor, the switch, and earth terminals, suddenly they worked again. Fiat reliability for you.
However, when you stop the wipers now they no longer return to the starting position and just stop wherever they are now even if its in the middle of the windscreen.
First thought would be a relay - But the uno doesn't have one??
Any advice?
Thanks in advance guys
1989 Fiat Uno 45 Fire
Needs: Paint, Bumper crack, Clutch, Water leak, window wiper spray fixed, a little rust and body repair, an oil cap, a boot strut, and some TLC
Some actual horsepower would be nice sometime too
I love this car to death
JohnWick is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: Front Wipers not returning to start position
Quote Originally Posted by JohnWick View Post
Hey everyone,
Any advice?
There is a switch contact insde the wiper motor that sets the park it is powered with the wiper set to off. There are two possible faults:
1/ Contact in wiper motor faulty
2/ No power to wiper motor in "off" stalk position (faultyl stalk, wiring or connector).
So first thing is to disconnect wiper motor connector, set stalk switch to off , ignition on and check with a voltmeter (or test lamp) for voltage on one of the pins. If there is voltages you need to repair or replace the motor. I don't know the Uno motor but generally there is a cover over the gear box the will expose the contacts. Cleaning the contacts (and possibly slightly bending any sprung arm) may be enough to fix it.
If there is no voltage at the connector it's likey to be the stalk switch but you should check the wiring too.
HTH,
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Thread Tools
(T) wipers have jumped position skeggylad Punto (Mk2/2b) 20 09-02-2015 18:31
(T) Front Wipers Upright Park Position Fiat04 Stilo 3 10-02-2011 15:21
(T) Headlight start/finish position? popsprocket X1/9 3 04-01-2010 11:41
(T) Wipers - work fine but stop in upright position pete10 Punto (Mk2/2b) 4 17-01-2009 17:51
Wipers do not park in right position on FIAT Marea 1996 Adi FIAT Boo Archives 0 24-03-2003 09:04
