Lamps by Post - For all your lighting needs
Thread Tools
Old 1 Week Ago   #1
South Africa
Real Noob Problem
Hi everyone, totally new to the forum. Loved the advice I found on here in the past.
I was wondering if anyone could help me. I have a 1100 fire 95 and the welch plugs were giving me hassles, the one wedged behind the flywheel to be exact. Anyway, I removed the gearbox, clutch, flywheel and replaced the plug that was leaking. Hoping that all was well I put everything back together again and tried my luck, unfortunately, no luck. The engine does not want to turn over???? I can hear the starter whizzing but other than that there's no life from the engine. Is there something I did wrong? Is there anyone that can assist please
Shamz
Likes Moimo liked this post
Shamz is offline Reply With Quote Quote
Old 1 Week Ago   #2
Re: Real Noob Problem
Quote Quote:
I had to Google 'welch plugs' .. I'd never heard of them before. In the UK they would be referred to as 'core plugs'.
Can you turn the engine over by hand - either by pulling the belt or with a socket on the crankshaft pulley?
That's just to make sure the engine is free and hasn't been jammed/locked somehow...
If the engine can be turned by hand that's pointing towards a starter motor that isn't meshing/engaging properly. You say that you can hear the starter motor whizzing, which tends to suggest that it's ok ..but not engaging with the teeth on the flywheel.
I don't know if it's possible to fit a flywheel 'back to front'.. but it does sound - from what you say - that the engine isn't turning over? Is the starter motor fitted in the correct position ...?
I have no doubt that others will post a reply .. but, whatever .. keep us updated.
The general rule of thumb is that if it worked before you fixed it, but didn't work afterwards .. it's something that you've done. I tend to think the fault is somewhere around the starter motor
Likes Shamz liked this post
glenn2602 is offline Reply With Quote Quote
Old 1 Week Ago   #3
South Africa
I'm taking her apart this weekend again. Hopefully I put the fly on back to front haha. Seems like the most simple fix right now
Old 1 Week Ago   #4
South Africa
Quote Originally Posted by glenn2602 View Post
Thanks so much. I'm probably to blame here haha. But that's the joys of noobdom, knowledge. I'll keep you updated with how the process goes a second time around
Old 1 Week Ago   #5
Quote Quote:
There's nobody on this planet who hasn't made a mistake with a car (maybe made many mistakes over many years..).
It's just how life is, Shamz. One day your car is okay and the next day ..
Keep us updated.
Old 6 Days Ago   #6
Trader Rating: 1
portland_bill has donated!
Most core plugs these days seem to be like a dish, with sides. Earlier plugs were often like a saucer, no sides, and these were called Welch plugs. I think the inventor may have been called Welch. History, before my time.
Quote Originally Posted by Shamz View Post
If the starter is turning, and the engine is not, then it is not engaging with the flywheel.
The solenoid on a pre-engaged starter should throw the pinion into mesh with the ring gear, and when the solenoid reaches the end of its travel, it connects the fat battery cable through to the actual motor windings, to spin the engine.
However, the earth path for the solenoid goes through the motor windings. If there is not enough power to move the solenoid, the small current passing through will often turn the motor. It sounds good, but of course there is no load.
Possible causes:
Not enough power in the battery.
Poor connections to the starter, either 12v feed or earth.
Tight/seized solenoid, lever, or pinion.
The earth cable from the battery goes to the body and the gearbox. If this is not refitted, or has a poor connection, or has broken along its length, your symptoms are what would be expected.
1. Ensure battery is fully charged.
2. Check connections and continuity of main battery feed cable to starter.
3. Do the same with the earth cable.
Earth cables seem to deteriorate inside their insulation, sometimes having a break inside, so not obvious, but will not pass large currents. Make sure it will pass big currents and that all connections are clean and secure.
To test, put a jump lead, like used for starting from another battery, between battery negative and engine block.
Thanks Shamz thanked for this post
13 years motor trade, 16 years motor industry. 13 years Driving Instructor & 6 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Old 5 Days Ago   #7
South Africa
So that's good news! I just need to charge her? ?
Old 5 Days Ago   #8
Trader Rating: 1
I think you'll find there was more to my post than that. If the earth cable is not passing the necessary current, it will be trying to find a path elsewhere. This can fry delicate components. Check the cables first.
Panda Alessi
Thread Tools
Punto (Mk2/2b) Noob says hi mipasodu Newbie Central 1 25-03-2015 10:05
(T) Went in with a real wheel bearing - car now has a head gasket problem/ecu fault Svenholio Punto (Mk2/2b) 5 18-05-2011 16:51
Noob Schmang Newbie Central 9 13-06-2007 10:59
(T) Noob with ECU problem hells Stilo 12 17-02-2007 14:11
