Thread Tools
Old 26-07-2017   #1
South Africa
Please help
Hi
Ive replaced my gearbox but now when my car is switched of it can go in gear but when its idling it don't wanna go in any gear, I have blead the clutch and cant find any leaks
Please help
viljoenbennie22 is offline Reply With Quote Quote
Old 26-07-2017   #2
France
Re: Please help
Clutch assembled backwards?
Steve145 is offline Reply With Quote Quote
Old 26-07-2017   #3
South Africa
Re: Please help
I didn't remove the clutch I only removed the gearbox to be repaired
Old 31-07-2017   #4
France
Re: Please help
Has to be either clutch or gearbox.
Could be that the gearbox was incorrectly reassembled?
Jack up both front wheels, with the car in gear (engine off), turning one wheel should cause the other to rotate in the opposite direction. With car out of gear, only one wheel should rotate (both may still turn, but an assistant should be able to stop the other one easily).
With the car on the ground and an assistant, try pushing it in neutral. Now try in gear, it shouldn't move. Now try in gear with clutch depressed, it should roll.
Look to see if the clutch release lever is moving when an assistant depresses the clutch.
Only things I can think of:
Clutch assembled backwards.
Clutch not releasing.
Gearbox has two gears selected at same time (jammed).
Old 11-08-2017   #5
South Africa
Re: Please help
Did you fit the release bearing?
brandtvdmerwe is offline Reply With Quote Quote
Thread Tools
