I have to agree with Kyriakos to some extent... but it also helps if you can drive a few other Unos of similar spec to decide what is 'normal' behaviour.
As for the gaskets, I'd clean the old ones with meths and use Loctite 518 Master Gasket. I wrote about this stuff a moment ago, I love it. It's translucent red, not made of silicones, and it only sets when there is no air (between surfaces). It sets quite hard, so it's not affected by oil or petrol. It's not particularly cheap, and your best bet for finding it is probably an industrial bearing shop (they will carry the other Loctite products as well, so make sure you get the 518!). It comes in a handy syringe (ideal for precisely applying a small bead) or in a larger tube (not so easy to use).
I was first introduced to Master Gasket about six years ago by a truck-racing mechanic (we were refitting an SU carb to my Austin Princess, the silicone sealant having gone all gooey). I didn't take much notice at the time, but re-discovered Master Gasket a couple of years ago, and I will never use silicone sealant again unless it was originally used (e.g. on the FIRE sump).
Master Gasket will dissolve easily in oil/petrol if not set (remembering that it doesn't set unless trapped between surfaces). This is good, because it means that there are no squashed-out slugs of rubbery silicones to travel around the engine and take up residence in the oil pump.
I'd just like to point out that I have no connection with Loctite (r), and also, Loctite make a whole load of silicone sealants which I won't use.
-Alex
