Fiat uno turbo original Member Parked in the garage Joined Dec 18, 2012 Messages 120 Points 51 Apr 9, 2015 #1 Hi all, does anyone know where I can buy a firewall for my mk2 uno turbo, mine has ripped because of the heat and age .
johorridoh Member Written a guide Joined Oct 30, 2010 Messages 261 Points 61 Location Duesseldorf Apr 10, 2015 #2 These are hard to find. Try to repair it with Aluminium foil.
E Ev0luti0n_FX New member Joined Mar 19, 2007 Messages 25 Points 5 Apr 12, 2015 #3 I've taken mine out, and had no problems with it. Driving around with one ripped might be prone for them to catch fire....
OP OP Fiat uno turbo original Member Parked in the garage Joined Dec 18, 2012 Messages 120 Points 51 Apr 12, 2015 #4 Yes thanks johorrodoh will try that out
OP OP Fiat uno turbo original Member Parked in the garage Joined Dec 18, 2012 Messages 120 Points 51 Apr 12, 2015 #5 Yes Ev0luti0n_fx that's what I want to change mine , but I think putting an new one or making one will brighten up the engine bay ei ?
R robotfireengine Banned Joined Sep 23, 2013 Messages 68 Points 17 Apr 25, 2015 #6 You should probably weld a plate in, or at least over, the hole. Or rivet it. Use the same type of metal as the firewall (you mean same as bulkhead, right?) is made from.
