hi all
i have a uno 1.1 (2000)
the thing i have had oil leak so the warning light came on , so i topped up the oil. i found the leak in between the engine and gearbox. so i assumed it was the rear main seal. so i dropped the gear box and changed the seal. then put everything back .started the car and it would not go forward only reverse. so a friend said it was the pressure plate. so dropped the box and changed the clutch and pressure plate. but now im having same problem:bang:. only goes in reverse. it struggles to even go a meter forward. please help.so could it be oil pump ???? or what
