The FIAT Forum
Old 08-09-2005   #1
faster! FASTER!!!
Trader Rating: (2)
bulldog5046 has donated! United Kingdom
wiring: UT rev counter > i.e Start
right, so i broke my speedo on my old clocks, went and collected a new lot last night and fitted them fine, everything that should work does.
now i want to have the rev counter operational, where on the back of the clocks should the cable from the coil go? and if anything other than the one from the coil is needed what and where does it go?
cheers,
Ryan Edge
The first UK Marea Turbo?
bulldog5046 is offline
Old 08-09-2005   #2
charlieboy's Avatar
Trader Rating: (4)
Re: wiring: UT rev counter > i.e Start
louie fitted SX clocks and had to add one wire.
look on http://www.fiatforum.com/showthread....ht=rev+counter that explains how louie got it working
ive just fitted a rev pod to mine and it didnt reallytake that long....untill i blew a fuse Doh'!
charlie
For Sale: BMC CDA, see classifieds!
Originally Posted by KoArAnG
Black wheels and silver cars are yummy
< Team Anthracite >
charlieboy is offline
Old 08-09-2005   #3
Fixin UnoTurbo I sleeper
Louie Bee's Avatar
Trader Rating: (6)
Louie Bee has donated! Netherlands
Hi Ryan,
As on my other tachometer thread , I connected a wire from the coil’s green wire nearest the passenger side Turret – directly on to the circuit board.
I have never seen the MK2 Turbo pod’s circuit board, I can’t confirm which pin you need to solder to. The way I worked it out was by tracing the copper track from the rev counter to pin.
When I wired in the taco to the MK1 turbo, and MK2 SX pod, there was only the 1 wire to add in.
Good Luck ,
Louie.
Now have aline of sight on finishing the MK1...
Just don’t know how long this line is
Louie Bee is offline
(T) Rev counter chaos Cinquecento / Seicento 137 12-04-2007 19:19
(T) rev counter - again! MILES Cinquecento / Seicento 1 02-06-2005 13:41
(T) rev counter puntostyling Punto 2 16-12-2004 10:35
(G) broken speedo + rev counter? Bushboy Uno 7 15-12-2003 00:17
FANCY A LAFF! RiB Leisure Lounge 4 03-03-2003 01:13
