Hi Matt,
There's not a lot available for the FIRE engine to really increase the power unfortunately.
However, check out smokeme's website, as he's produced excellent results by turbo charging it.
http://smokeme.coconia.net/index.htm
Other than that, you're fairly limited to induction kits and exhausts, though don't expect much of an increase in power from either.
Apparently fitting the Panda 4x4 camshaft will liberate an extra 5hp! I haven't tried this myself, but the power figure for the 4x4 Panda is 50bhp from the 999cc FIRE compared with the standard 45hp from all other Uno/ Panda 999cc engines.
The 1.3 twin choke carburetor will NOT fit the FIRE manifold. The flanges are totally different - the FIRE uses a two bolt circular fixing whereas the non FIRE ohc uses a four bolt square flange. It might be possible to have an adaptor made, but bear in mind you will also need a new throttle cable bracket as the twin choke carb uses a different layout.
The easiest way to increase the power is to fit the 1108cc FIRE engine from an early carburetor mk 2 Uno 60. And if you were to convert to injection you could then fit the 1242cc SPI Punto engine.
Or buy a rotten turbo and swap over the turbo engine and suspension and you'll have a real road burner!
But a simple swap to a free flow air filter is a start, as is making sure the engine is in a good state of tune (timing, ignition system/ wires, spark plugs etc.) Cleaning out the carburetor is not likely to increase power unless it is very dirty, but will help make it work at 100% efficiency. It's still worth doing though, and while you're at it you might as well buy a rebuild kit and change all the gaskets and diaphragms etc. It's a simple carb to work on so there are no real problems when doing this.
If you manage to find an easy power increase then let me know because I'd love to get more out of mine!
Chas
