The Y10 Turbo uses a totally different engine (the Brazil engine) to the FIREs fitted to your Panda. I can almost guarantee the exhaust manifold from a Y10 turbo will not fit without serious bodging.
Your best bet is to pop over to the Cinq section and look at the FAQ regarding turbo charging a Cinq Sporting. They also use the FIRE engine so most of the info you're seeking can be found there.
Custom manifold is only option really. arc had one for sale a while back, that he had custom made for the FIRE engines and i think the flange was for a gt15. PM him, might still have it.
Takes alot more than manifolds for turbocharging.
Will need a bigger carb, bigger cams would be better too i think. oilcooler and intercooler + pipework. Decom plate and maybe custom/upgraded internals
May be the same turbo from the astra 1.7TD engines. they a garret and recomended for conversions. Weren't Vauxhall at one point making cars using the Fiat engines?
Well my intention is only to run a low boost setup and gain somewhere in the reigon of 50-60 bhp.
Not a chance if a reliable doubling of HP sorry.
My other half had her seicento done a few years ago by Van Aaken and the 1242 fire went from about 65 to 95 at 0.4bar.
It's a really fun drive, but from 45hp to 105 is way too much if you want to keep reliability. it's a torquey engine and with the T15 the boost is almost always there which is what you really want
Here is the rolling road print from my 903 https://www.fiatforum.com/uno/224599-mk1-rolling-road-graph.html LOL
And this is from when she had the turbo installed https://www.fiatforum.com/gallery/showphoto.php?photo=39002&size=big
Whats the point in fitting a turbo to a 999cc when you could just fit a 1242? Will cost less, be alot less hassle and it will also be more reliable.
4x4 cams are quite hard to get hold of. I can think of one member who might have a spare. Alternatively you can fit the cam from the 1108 engines or perhaps from a 1242. will need to be accompanied by a bigger carb though i expect.
T15 on a fire?
Doable... been there, done that...very rewarding stuff....very expensive if you do it well....
