| Leaded or unleaded? I have just bought, don't laugh. An Uno CVT Selecta 1116cc. 1989 (F) 47,200 miles one owner. Apart from a few scabs on the bottom of the doors, it is really a sound car and ideal as a runabout for my youngest. The question I have is, does it use the old four star leaded fuel, or unleaded. Your help appreciated.
| | #2 | |||||
| Classic Uno Obsessive | Re: Leaded or unleaded?
According to Mr. Haynes (worshop manuals), you can use unleaded (minimum 95 RON) in the following models with the indicated serial numbers: 903cc - 146A.000, 146A.046 999cc - 156A2.000 1116cc - 138B.000, 138B.046, 146A4.000, 146A4.048 1299/1301cc - 138B2.000, 138B2.046, 149A7.000, 1149A7.000 I think the serial number is stamped on the chassis plate, under the bonnet. It might also make up part of the engine number, though I can't remember off hand. A good rule of thumb as to whether an engine can run unleaded fuel or not is if it has an aluminium head. If the head is aluminium, then valve inserts have to be used as alloy is too soft to have valves working directly on the them. Most cars with alloy heads have hardened valve inserts/ seats, so in theory can run unleaded. Only thing to watch out for when switching to unleaded is to see if the engine 'pinks' or 'knocks' (predetonates) under hard acceleration. If it does then the timing will have to be adjusted to stop it, as pinking can cause damage to the engine. Good luck with your new Uno, and if you have any other questions please feel free to ask away. There are a lot of knowledgeable people on here who will be happy to offer advice. Chas
| | #3 | ||
| Fixin UnoTurbo I sleeper | Re: Leaded or unleaded? I doubt anyone on here will be laughing for you excellent choice That is really low mileage do you have any pictures?Kind Regards, BTW I think Chas is answering the fuel question on your Non Fire OHC 1116CC Uno. – ah He just posted it – Nice One!
__________________ Louie. Now have aline of sight on finishing the MK1... Just don’t know how long this line is | ||
| | #4 | ||
| meow | Re: Leaded or unleaded? i want pictures! and good choice of car
__________________ ![]() 1993 Uno Turbo / 1995 Punto 55 / 2000 Punto JTD 1998 Punto Sporting / 1993 Ford Escort 1800 16v / 1998 Fiat Bravo HLX | ||
| | #5 | ||
| Re: Leaded or unleaded? I only have the one picture, until I get chance to do the scabs on the bottom of the doors I have raised the underseal of the sills to include an inch of the doors.
| | #6 | ||
| Fixin UnoTurbo I sleeper | Re: Leaded or unleaded? I did the same on my first Uno to hide poor rust work.
| | #7 | |||||
The door bottoms rusting is a weak point on the Uno. Normally when rust shows on the outside, it means the door has rusted from the inside out. Not good! To help prevent rusting, take off the door panel and inject rustproofing wax all over the inside, taking special care to get it in where the door skin meets the door frame and all along the bottom of the door frame itself. That should hold the rust at bay for a while. Anyway, good luck with your Uno and enjoy the forum. Chas
| Is it true Tescos sell 99RON Unleaded? | Liam | Leisure Lounge | 46 | 23-07-2005 20:37 |
| Unleaded octane question. | Morty Mort | Lets Talk FIAT | 2 | 29-04-2004 16:31 |
