Thread Tools
Old 18-01-2012   #1
South Africa
1400 gearbox on a 1100
Is it possible to mount a 1400 uno gearbox to a 1100 uno motor? Just a straight forward bolt on. No modifications. The reason I ask is my gearbox is on its way out and I'd like to if I can put a 1400 box on because of the longer ratios
unochris is offline Reply With Quote Quote
Old 18-01-2012   #2
a73uk has donated!
Re: 1400 gearbox on a 1100
The short answer is no, The 1108 FIRE engine is completely different to the 1400, so the bell housing etc is different.
Might be worth looking into the current 1400 FIRE engined Fiats to see what the ratios are, it should go on without trouble as long as you have `dry` inner driveshaft gators & a cable gearchange on yours.
Currently got.. 89 Panda 750L, 1989 Uno 45S, 90 Uno 60S, 99 Sei Sporting, 2000 Sei Sporting, Jaguar XJR V8, Porsche Boxster, Daimler 3.6, Jaguar X300 Manual, 2012 electric motorbike.. The 1990 Uno is the most fun!
a73uk is offline Reply With Quote Quote
Old 18-01-2012   #3
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Louie Bee has donated!
Rollin X Pinball Champion, Bubble Bobble Champion
Mozambique
if you have the old 1116cc then maybe.
If you have the 1108 fire then probably not.
the 1116 engine and the 1372 nat asp box should go - diferent gear linkage though - not sure on drive shafts and speedo cable.
the 1116 engine and the 1372 Turbo should go but drive shafts and hubs need to be replaced as well as gear linkage and probs cable.
If you have the 1116, best looking for a 1116 / 1299 / 1301 nat asp box, or 999/11880 box if you got the 1108
Louie Bee is offline Reply With Quote Quote
Old 18-01-2012   #4
South Africa
Wow ok haha. I think I'll just replace it with another 1.1 gearbox. Sounds like its going to be the easiest. I don't have a uno motor in my car, its a palio 1242cc mpi motor
Old 03-08-2017   #5
South Africa
Re: 1100 gearbox on a 1400
Hi
Can I fit a 1100 gearbox in a 1400 uno ?
viljoenbennie22 is offline Reply With Quote Quote
Old 03-08-2017   #6
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Quote Originally Posted by viljoenbennie22 View Post
Hi
Quote Originally Posted by a73uk View Post
Eklipze3k is offline Reply With Quote Quote
Thread Tools
(G) 1100 or 1400 handsome Other Fiats 2 05-11-2009 20:25
(T) Uno 1100 Gearbox Scary1 Uno 0 10-02-2008 17:41
(T) 1600 16v to 1400 uno gearbox fit. M@nticore Uno 5 26-09-2006 15:52
(T) About fitting a 5-speed gearbox in 128 1100 cc ahmad_abdallah Other Fiats 1 19-05-2006 10:17
(T) 1100 uno gearbox torque settings M@nticore Uno 5 31-07-2005 13:53
