My car is a Fiat Uno 1.1 ie from 1992.
The stepper motor doesn't work. When I give ignition it push out itself and after it still in this position, not move. The stepper motor is good, because when I check it directly from the battery it works in both direction. If I disconnect the plug from the potentiometer of the injector during the ignition at that time the stepper motor goes back, if I connect it, it comes out. The complete injector was replaced for a new one but the situation is the same in both case. Currently the stepper motor is out of the engine and the car goes without this.
I already made ECU reset.
Could You help me?
Could You help me?
