Technical sloppy gear linkage
willsrings
Hi, Does anyone know if it is poss to change the bush in the reverse gear rod at the gear stick end, or is it necessary to replace the linkage?There is a lot of side to side movement in the stick and it looks like the bush has broken up from the socket.
This is on a Fiorino 1.7 TD! But at least it is a Fiat and Uno based!
