The FIAT Forum
Old 03-03-2005   #1
Trader Rating: (1)
Luke has donated!
Unhappy Bad noise
I seem to have a bad noise coming from the right hand side when turning hard(ish) to the left. Jacked up the car and fiddled with the wheel while its in gear and it still turns a bit and knocks quite bad.
Now all the signs suggest that i have a worn/broken CV joint. NOT good news if it is. Gotta wait 'till my dad gets in and double checks thats the problem before i go cry a little then hit the prozac before getting prices for a new joint/ say balls and get another and break this one.
Luke is offline
Old 03-03-2005   #2
Trader Rating: (0)
Re: Bad noise
sounds like bottom ball joint. Quite an easy job really.
sterryroad is offline
Old 03-03-2005   #3
Trader Rating: (1)
ts86 has donated! United Kingdom
Re: Bad noise
It's a wear and tear part. Just get it fixed at some back street garage and that'll be that.
It's sometimes actually worth it to keep old cars on the road.
145 QV
156 2.4 JTD
ts86 is offline
Old 03-03-2005   #4
Trader Rating: (1)
Luke has donated!
Re: Bad noise
oh i can fix it myself, that aint a problem - its paying for the parts thats the problem.
Luke is offline
Old 03-03-2005   #5
Trader Rating: (1)
Re: Bad noise
Oh, cool. Parts should be no more than £50 for a pair?
145 QV
156 2.4 JTD
ts86 is offline
Old 03-03-2005   #6
Trader Rating: (1)
Luke has donated!
Re: Bad noise
well me old mans just come home, just plucking up the courage to go back out in the freezing cold to do some more diagnosing. Fingers crossed!
Luke is offline
Old 03-03-2005   #7
Fixin UnoTurbo I sleeper
Louie Bee's Avatar
Trader Rating: (6)
Louie Bee has donated! Netherlands
Re: Bad noise
Hi Luke
You’re sure its not just the exhaust’s heat shield? Mine rattles a lot on long tight left bends.
Also, check the rear upper shock mountains for a tare. Before I had new suspension, I had to leave off the one of the rear upper shock mount covers. The top of the shock absorber was knocking against it while my Uno settling.
– Prozack – NOOOOOOOO – I’d like to Edit: I’d better watch my lip lol .
Kind Regards,
Louie.
Now have aline of sight on finishing the MK1...
Just don’t know how long this line is
Louie Bee is offline
Old 03-03-2005   #8
Trader Rating: (1)
Luke has donated!
Re: Bad noise
Nope, it's definately a CV joint. Great stuff, now i'm stuck without a car
Luke is offline
Old 06-03-2005   #9
Back once again w'the...
alexGS's Avatar
Trader Rating: (1)
alexGS has donated! United Kingdom
Re: Bad noise
Seems unusual for the right-side CV joint to fail (in RHD countries, you always do a U-turn to the right, so the left side joint seems to wear out first!)
As for slackness in the driveshaft, that's normal up to a point.
Anyway the parts are not that expensive, 2nd-hand would probably be OK (preferably taken from the RH side), and you can pay someone else to replace it if you have to, because it doesn't take long with the car on a hoist, with air-gun etc.
I agree with Sterryroad, bottom ball joint is a common culprit or perhaps wheel bearing, but bottom balljoint would be making a knocking in the steering, and with this (or wheelbearing) you'd be able to detect 'waggle' in the wheel when jacked-up.
CV joints usually make the cracking noise first, when they get worn, during full-lock turns only. Usually the noise comes on very gradually as the car ages. Sudden noise means you're right to investigate the problem!
Thanks,
-Alex
'01 Punto Sporting Speedgear, '88 Uno Turbo i.e., '91 Alfa Romeo 164 3L V6 Manual, '03 Suzuki SJ50QT (!)
Originally Posted by Deckchair5
New switches are £5 from Fiat. Not too difficult to fit but I’d advise practising shuffling a deck of cards with one hand in the dark upside down first.
alexGS is offline
Old 06-03-2005   #10
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
Re: Bad noise
Originally Posted by Louie Bee
Hi Luke
Kind Regards,
Hei.
Mine was like this for over a year now. Then the backbox fell off two days ago. No more rattling on left turns. Haha. Straight through pipe is bought to replace the backbox.
Morten.
jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint.
member of the 5-door massive attack.
Morty Mort is offline
Old 06-03-2005   #11
Drinu's Avatar
Trader Rating: (0)
Re: Bad noise
I know this might sound silly but I had the same problem once because I didnt tighten the wheel nuts properly of the front wheels!! Try tightening them, they might have loosened up!! That's what solved the problem for me (PHEW!!). You wont be missing out on anything!
Hope this helps!
Ad
Mods:
Clear indicators
GT Auto Alarm
White dials
Autometer Rev-counter
Boot light
Alloy wheels 185/55 R14
Sprayed Disc brakes
x2 8" rear speakers
x2 4" front speakers
Kenwood CD player
Drinu is offline
Old 06-03-2005   #12
Trader Rating: (1)
Luke has donated!
Re: Bad noise
I've had both wheels off and back on again since (so wheelnuts are tight) and the noise persists Not totally convinced where the noise is from now tho. I've fixed a number of loose things yesterday but havent driven it since to see if the problem has been rectifcied.
Luke is offline
Old 06-03-2005   #13
smurfhead's Avatar
Trader Rating: (0)
Re: Bad noise
Make sure if the CV joint is worn, don't drive it too much. The 306 at my house had a work one last year and my mate was driving it down a straight road, and his wheel just suddenly turned inward and put him up a pavement. quite unsafe as we know now from experiance. shouldn't take you too long to repair. me and him did it one morning and we are no experts.
Gaz
smurfhead is offline
Old 07-03-2005   #14
Classic Uno Obsessive
1986Uno45S's Avatar
Trader Rating: (0)
Drives:
1986Uno45S has donated! United Kingdom
Re: Bad noise
Have you checked the wheel bearings? Jack the car up on the side that is making the noise. Grasp the wheel at each side and try and wiggle it. Also do the same at the top and bottom position. If the wheel bearings are worn you'll hear a clicking noise along with feeling some free play. Sometimes retorquing the wheels bearings might help, though bear in mind they are done up to a VERY high torque setting. Something like 200 ft/ lbs, a rating higher than most torque wrenches go up to.
1986Uno45S is offline
Old 07-03-2005   #15
Trader Rating: (1)
Luke has donated!
Re: Bad noise
Bearings should be fine, but if the noise is still there i'll give it a check
Luke is offline
(T) Strange noise and start up problem. El Greeno Uno 18 23-02-2005 10:47
(T) continuous clicking noise wiper motor? HELP nickphonics18 Punto 2 13-02-2005 15:14
(T) Rattley/knocky noise simon1978 Punto 2 31-01-2005 23:22
Noise from Air Vent/Turbo Lou Ulysse 7 07-06-2004 04:27
(T) Rear noise when moving off Paddy_Punto Punto 2 25-12-2003 18:42
