| | #1 | |||
| clutch.... think my clutch is on its way out, cant get reverse without massive grinding noises and can only seem to select 3rd when stationary an 3rd and 4th when moving. is this my clutch and how much if it is? cheers charlie
__________________ For Sale: BMC CDA, see classifieds!
< Team Anthracite > | ||||
| Re: clutch.... The crunching reverse is quite common with the uno The rest however isnt.Theres a little plug in the gearbox housing near the engine. If you take this plasitc cover you can see the thickness of the clutch plate and see if its worn or not. It the dark grey material eitherside of a metal plate which you are looking for. If its very thin then yes it could be on its way out. Other things it could be is a gearbox fault... If the clutch had gone, in theory you shouldnt be able to select 3rd or 4th either - it wont go in any gears at all. Could be your clutch cable has stretched, so you need to retighten the cable thats attached to the gearbox operating arm.
| | #3 | ||
| Fixin UnoTurbo I sleeper | Hi charlieboys93UNO, I have had similar problems but wi 1st and 2nd. See http://www.fiatforum.com/uno/21132-uno-wont-go-into-gear.html and try double d clutching, and changing gearbox Oil first -as you have the same box as me lol. You could try http://www.shop4parts.co.uk/ Or http://www.buypartsby.co.uk/sitemap.php for clutch parts. I’d go to one or two garages and ask them "how much for a new clutch" (Parts and fitting - but they will presume you mean this). Then ask them for a breakdown quote, then if you can get the parts cheaper, ask them if they will do a fitting only. They will prob. tell you they can’t guarantee the parts, but you have the shop guarantee, and their fitting guarantee. You have to be 100% sure you order (and get) the correct part each time you use this root lol. Kind Regards,
__________________ Louie. Now have aline of sight on finishing the MK1... Just don’t know how long this line is | ||
| | #4 | |||
| Re: clutch.... cheers guys, it seems that when selecting 3rd 4th i have to kinda knock the s*** out of the gear stick to get it in luke, i never had crunching on my reverse before,yday it was a little crunchy loud, but before the weekend it was fine had no problems with any of the gears cheers charlie
| | #5 | ||
| Re: clutch.... Strange, a few people have mentioned a crunchy reverse on fiats in general. Mines always crunched and the clutch is fine.
| | #6 | |||
– Each time it gets harder? What next? You’ll end up needing a new gearbox if you don’t pack it in lol. Use Double D Clutch to help glide her in gear lol. It might also be the bar at the back of the box seizing up. Kind Regards,
__________________ Louie. Now have aline of sight on finishing the MK1... Just don’t know how long this line is | |||
| | #7 | ||
| Fixin UnoTurbo I sleeper | Re: clutch.... Hi Again, Just remembered Kind Regards,
| | #8 | |||
| Re: clutch.... louie its not gettin worse i havnt used the car since this morning when i discovered the problem, i was just adding to the description.lol double D clutching? youve lost me could ya xplain please.lol. cheers charlie
| | #9 | ||
| Fixin UnoTurbo I sleeper | Re-clutch.... Hi Charlie, I meant over the next few weeks / Months – If you push the stick harder as the problem gets worse – something more expensive will give lol. I know it’s cumbersome, but will extend the life of the box till you get it sorted. I have the odd problem wi 1st and 2nd – so each time it will not easily glide into gear, I release and re-dip clutch then try again. When my clutch went (in a 903) the clutch plates were not holding together and transferring the engine power to the wheels – Loads of revs in gear – getting nowhere – and worse up hill lol. Kind Regards,
| | #10 | ||
| 3rd Gear Spins Anyone? | Re: Re-clutch.... mine crunches into reverse all the time. and also find it hard to get into 1st sometimes. need to check the hydrolic clutch on mine in case the seal is leaking. Dunc
__________________ Uno Turbo i.e Uno 1.0 (Will be given a turbo lump soon) Fabia VRS S14a 200sx - R.I.P | ||
| | #11 | |||
| Re: problem solved jus been out to the car (as jus got in from school )me and my dad bled the cluth (was hydralic louie plus there no crunching for reverse AT ALL !! lolcheers charlie
| | #12 | |||
. If you don't know when or if the gear oil was last changed - I'D get some (from FIAT dealer) and start fresh...Kind Regards,
| | #13 | |||
| Re: clutch.... its just a temp thing till the weekend, hopefully it should hold out (fingers crossed!! ) charlie
| | Julio_Scorchio | Cinquecento / Seicento | 21 | 2 Weeks Ago 03:02 |
| | SnowBord | Cinquecento / Seicento | 12 | 13-02-2005 18:18 |
| | radicool | Punto | 2 | 19-11-2004 22:57 |
| | stiloactive | Stilo | 2 | 25-06-2004 04:05 |
| | slf_16 | Punto | 2 | 26-05-2004 02:15 |
