Helooo,
As most of you won't know, I am fitting Leweys Uno Turbo Guy Croft spec engine into my Panda to make it somewhat faster.
Anyway I have a few questions you Uno guys may be able to help with.
I am building the engine from parts in boxes and so far just need a full gasket set and a set of standard pistons.
What is a good baseline boost setup? Should I run with a stock boost figure untill I can get to a RR and get things figured out?
Also what is the general rule for finding maximum safe boost? Do you just keep going untill you hear/find/see pre ignition?
Furthermore, I am in need of a turbo. The exhaust can mount a Garrett T25 turbo, but I'm a little concerned that due to the low weight of the Panda ( +/- 700kg) it will just have pure wheelspin off the line, so I'm thinking of something that boosts a little later on in the RPM range.
How do people here find their stock T25, I believe from a Saab or something? Not really looked into it properly.
Anyway, just a few thoughts. Any answers appreciated
