Hello everyone! I've been searching the internet for people with the Uno 1.1 I.e-S. I found this forum and i thought i would just ask some questions here. I see that there are a lot of people with auto mechanical knowledge. Anyways hope that is ok.
First of all I live in Norway, cold country up north. I own a Fiat Uno 1.1 I.e-S mk II. It was first time registered in 1994 but i think it was made in 92-93. The sylinder volume is 1108ccm and has approximatly 50bhp( probably alot less now) This car is stamped as a **** car in Norway, I think the mk II both design and fuel consumption wise is pretty good. The car hasn't got that much rust on the body, but underneat there is quite some rust.
I've done some repairs to it( or maintenance)
- Changed Exhaust pipes( the pipe from the manifold, and the muffler part. Not the catalysator part)
- Changed o-ring on Distributor( it was all crispy)
- I paid two different mechanics to seal the oil leak from the top cover or what it's called, but they did a **** job and its still leaking.)
- Going to change break lines at the back( all rusted, or the EU control guys are trying to get money from me :S)
- The windshield washer fluid pump for the back window doesnt work.( is it completly broken or can i fix it?)
I'm having problems with condense build up inside the car, this is bad at winter times when its -20C outside. The door at the driver side and the front passenger side often gets stuck at winter and i sometimes have to go in through the luggage compartment Also at these degrees the lock gets frozen and the door wont shut when i finally get it up.
So can someone with experince give me some tips on what i should do to make it easier at winter times and also keeping my car alive generally ?
Some questions:
- Is it possible in any way to tune or increase the performance of the engine? its driven 120 000 km
- Is it possible to change the engine? ( what engines are compatible)
- Are there problems which will occure if i dont take certain measures? ( what measures?)
Thanks to the guys who will take time to answer me
Some questions:
