135/80R13
that's the 999cc Uno size
I just need a 999cc Uno to go with them,
did you cut the outer diameter of the outer ARB bushes down
. I had to to avoid contact with the CV boot. they are a diferent design to the OEM ones, but won't matter till your front wheels leave the ground with spinning wheels :devil:.
Oh don't the nat asp thermostat open at a diferent temprature to the turbo one
. won't that explain why the blank boss which could have been drilled, tapped then pluged (remove if needed) to avoid 2 similar parts for the aftermarket? :bang:
