LOL Misunderstanding.
There were 5 punctures in 1 tyre when I got the car.
They used one of these kits to repair it:
From what I have been told I need a new steering rack. (I will be looking into this over the weekend).
The symptoms include:
When driving at any reasonable speed the car feels as if it is pulling/sliding toward the left then to the right.
There is play in the steering wheel.
When the car is standing still (key in engine off) and you turn the steering wheel it makes a very loud squealing noise.
When driving the car also makes grinding noises when you accelerate or hit a bump.
When you turn the wheel while moving slowly the squeaking noises are accompanied by the occasional bumping/clonking noise.
Is there some test to see if it is the steering rack? (they have replaced tie rod rack ends, ball joints e.t.c. and it helped for a few weeks but the problem is back).
The car was basically the factory bicycle and has been around the block several times already.
I also know the left wheel bearing is going (very noisy), right hand cv joint inner and outer need replacement, speedometer is not working at present and there are several other faults that slip my mind right now.:bang:
