| | Problems with gearbox Fiat Uno Mk 1 Hi guys, I'm having problems with my 4-speed gearbox. Its hard to get in 3rd and sometimes i have problems with 1st and revers too. But mainly with 3rd gear. I have checked the gearchange rods below the car and they are a bit slugish. Could it be the problem or is there another reason?
| | #2 | |||
| | Re: Problems with gearbox Fiat Uno Mk 1 Have you checked that the clutch is adjusted correctly?
__________________ ![]()
| | #3 | ||
| | Re: Problems with gearbox Fiat Uno Mk 1 dont think its the clutch first and reverse would be a dog to get in if it wasnt clearing fully ,have you changed oil in gearbox or even oil level ??
| | #4 | ||
Posts: 777 Thanks: 26 Trader Rating: 0 | Re: Problems with gearbox Fiat Uno Mk 1 As above, plus lubricate the pivot shaft (if there is one, not sure on the 4 spd) just behind the gearbox as they can seize up. Also if theres any oil leaks, even from the distributor above the gearbox, it can cause clutch, & therefore gearchange issues.
__________________ Currently got.. 89 Panda 750L, 90 Uno 60S, 93 Tempra 2.0ie SW, Jaguar XJR V8, a Porsche Boxster, 2x Daimler XJ40`s, 96 Punto 1.6 Sporting (breaking). The Uno is the most fun! Last edited by a73uk; 28-01-2010 at 06:37. | ||
| | #5 | ||
| | Re: Problems with gearbox Fiat Uno Mk 1 Thnx for replays guys, will check it asap. I'll let u know if it helped. ![]() PS: Last owner changed clutch disk.
| | #6 | |||
| | #7 | |||||
problem is mostly in 3rd gear ,i sugested checkin oil as they all or atleast most unos leak oil out drive boots if clutch was prob it would crunch in every gear ????
| | #8 | ||
Posts: 546 Thanks: 51 Trader Rating: 0 | Re: Problems with gearbox Fiat Uno Mk 1 Plus over time the synchro rings tend to wear out on 3rd gear before the other gears Because drivers tend to change down too early and/or too quickly from top into 3rd | ||
| | #9 | ||||||
![]() Also the drive boots shouldn't leak at all if in good condition. They only leak if they are old and need replacing!
| | #10 | ||
| | Re: Problems with gearbox Fiat Uno Mk 1 Hi again Seems that this gearbox problem has solved itself, gears are fine now. Just changed the engine oil and going to change gearbox oil too. So i'll see if it makes the gears smoother. So i'll update the thread wen i have the results.
| | #11 | ||
| | Re: Problems with gearbox Fiat Uno Mk 1 sometimes these things are all in our heads LOL ps collect gear oil in clean tray to check for metal fileings .
| | #12 | ||
| | #13 | ||
Posts: 546 Thanks: 51 Trader Rating: 0 | Re: Problems with gearbox Fiat Uno Mk 1 When I drained the oil from my gearbox last August it looked like it had loads of christmas glitter in it | ||
| | #14 | ||
| | #15 | ||
Posts: 546 Thanks: 51 Trader Rating: 0 | Re: Problems with gearbox Fiat Uno Mk 1 You should find that the drain plug is magnetised SO it will usually have some tiny bits of metal on it My oil was full of glitter because the wrong oil had been put in previously and the 3rd synchro has pretty much totally gone | ||
| Tags |
| 4 speed, fiat, gear box, mk 1, uno |
| | Brian M | Uno | 4 | 12-10-2003 20:47 |
